No Application Data PMOS 21.12.1
I want to know the answer, too.
The closest you can get it to 'work' inside 'Software' I found is to install flatpak:-
sudo apk add flatpak
(of which some applications are working, but not all of it will work. Eg. Giara (Reddit), Axolotl install via 'Software' did not work for me -Giara worked in Ubuntu Touch however)
See also:
https://wiki.postmarketos.org/wiki/Flatpak
RE: No Application Data PMOS 21.12.1 - by chadwick - 01-20-2022, 11:38 PM
RE: No Application Data PMOS 21.12.1 - by Gon - 08-12-2022, 07:42 AM
  Fresh install pmos+phosh does not boot user641 1 429 10-08-2023, 04:04 AM
Last Post: user641
Question Always Use Mobile Data DingDangDoong 4 1,741 04-20-2023, 06:18 AM
Last Post: DingDangDoong
  Boots To Shell After Dead Battery (PMOS) britelite 0 667 02-17-2023, 02:41 PM
Last Post: britelite
  Disable mobile data auto-enable on boot 64_Tesseract 3 2,183 08-11-2022, 02:48 AM
Last Post: 64_Tesseract
  pmos/phosh edge update and audio disappears robthebold 9 5,236 07-10-2022, 03:26 AM
Last Post: arkadione
  wwan0 (cellular data) ip configuration is POINTTOPOINT not BROADCAST dc2daylight 0 1,015 04-07-2022, 07:16 PM
Last Post: dc2daylight
  Calls don't work on Softbank. Cellular data & SMS work. yasmi 1 1,542 03-24-2022, 04:10 AM
Last Post: yasmi
  Application list PMOS-Phosh jmorris 6 5,928 12-04-2021, 02:26 AM
Last Post: Juergen
  Backup user data and settings kratz00 4 5,097 02-28-2021, 03:39 PM
Last Post: kuleszdl
  PMOS test image: failed EG25 test broke modem fw MtnSk8 4 5,516 02-28-2021, 02:20 PM
Last Post: MtnSk8
