PinePhone "click" or "tic"
Video
While i'm trying to get to the bottom of the audio issues,
Since i turned it on for the first time, it "tics" or "clicks" when booting or occassionally throughout its operation..
Is this normal? It comes from the rear lower half of the phone...
Cheers
That sound is most likely coming from the rear camera and yes it's "normal". I'd like it to not do that as well but I've not looked too far into fixing it. If you disable the camera with the DIP switch on the back of the phone it'll stop but then of course the camera won't work until you turn it back on haha.
(01-10-2022, 02:20 PM)Merc Wrote: That sound is most likely coming from the rear camera and yes it's "normal". I'd like it to not do that as well but I've not looked too far into fixing it. If you disable the camera with the DIP switch on the back of the phone it'll stop but then of course the camera won't work until you turn it back on haha.
Ahh Merc, Cheers!
As you say, it's annoying isn't it!
Thank you!
GJ
  Slarm64 on PinePhone [Unofficial Slackware ARM - 64 bit] acid andy 33 24,390 04-09-2024, 01:17 PM
Last Post: donchurch
Wink PINEPHONE not booting Touchwood 2 403 02-23-2024, 07:27 AM
Last Post: Touchwood
  Slack on PinePhone Adam Seline 5 5,327 12-20-2023, 07:20 AM
Last Post: nickolas
  Struggle to install LibreOffice on the PinePhone Peter Gamma 48 23,898 11-24-2023, 07:02 AM
Last Post: Peter Gamma
  Which word processor to choose for the Pinephone? Peter Gamma 8 1,913 11-23-2023, 01:06 AM
  openSUSE for Pinephone Alefnode 75 101,169 11-17-2023, 08:37 AM
Last Post: Uturn
  Using Signal on PinePhone in mid-2023? dante404 45 12,849 11-17-2023, 04:23 AM
  Genode- Sculpt OS for the PinePhone (non Linux) Surehand53 1 946 11-04-2023, 07:23 PM
  Abiword as a office mobile word processor for the Pinephone? Peter Gamma 11 2,121 10-24-2023, 08:57 AM
  What File Manager Options Are There For The Pinephone? pinephoneuser22 7 2,334 10-18-2023, 08:37 AM
Last Post: luppivega
