Nextcloud folder (WebDAV) not showing up in Portfolio
Hi everyone,
For a while now, I haven't been seeing the Nextcloud file system showing up in Portfolio when I connect a Nextcloud Online Account.
I seem to remember that it worked when I first received my Pinephone at the end of 2020 with the original Manjaro version that it came with from the factory, but I have performed fresh installs of newer Manjaro versions several times now.
"Files" and "Documents" are activated in the Online Account options.
Connected address books and calendars are working fine, so this does not seem to be a general problem with my Nextcloud account.
I see someone recently reported a problem with WebDAV here, but I'm not sure if it's related: https://forum.pine64.org/showthread.php?...=nextcloud
Is anyone else experiencing this?
Thanks!
WebDAV, CalDAV, cardDAV all seem work in progress to me. The phonebook seems to work halfways, as long as you don't ask for seeing someone's multitude of phone numbers, and also you should not edit or sync any adresses. If you delete the nextcloud account the contacts will stay and duplicate if you re-create your NC account. Well, and calendar events, or to-do's are not yet there. (but now we have waydroid and it's pretty painless to have it fully connected with nextcloud.
probably, as time goes by, theses issues will be worked on.
  CardDAV / Nextcloud sync broken Uturn 0 1,295 06-15-2023, 12:41 AM
Last Post: Uturn
  .CSV Without Nextcloud food 5 3,772 01-24-2023, 03:51 PM
Last Post: alaraajavamma
  nextcloud setup mruser1 2 2,804 12-05-2022, 03:22 AM
  how to connect calindori to nextcloud? Uturn 2 3,295 06-26-2022, 02:09 AM
Last Post: wibble
  App Menu showing but not usable jojuma 4 4,063 11-04-2021, 09:18 AM
Last Post: jojuma
  nextcloud contacts are duplicating Uturn 1 2,740 10-24-2021, 01:35 AM
Last Post: user641
  Plasma Mobile, Nextcloud account Uturn 1 2,793 03-05-2021, 09:14 AM
Last Post: Veraendert
