Pinephone shuts itself down
This problem occurs only when phone is unplugged.
I've set up the phone "Automatic Suspend" to 15 minutes when on battery and turned off the switch when Plugged In (so never Automatic Suspend when the phone is plugged).
"Screen Blank, Turns the screen off after a period of inactivity" is set at "never".
Problem is, when the phone is on battery, shortly after the 15 minutes to "Automatic Suspend", the phone seems to turns itself off. Power off.
I try to connect to SSH during that state, no connections, no ping, phone doesn't respond.
I tried to press the side button and wait around 6 seconds to press it again, still nothing.
The only way to get the phone back to work is hold the side button long enough for the small green led to lit then, the phone reboots.
I had this problem a while back (months back) but it did seems to have ended but now, for 1 week, that problem is back.
Im using Mobian with Bookworm on SSD and all the apt update apt upgrade frequently. 32gb phone model.
Thank you all in advance!
I have the same problem.
Mobian with bookworm.
However, I have not noticed a pattern yet.
Tja, I just said it and now it happened again.
Almost every day out you have to reboot at least once.
I wonder if it can be related to the telephone module.
I feel it does not happen on Wifi.
The tricky bit is to notice that you need a reboot,
as this happens after you have not used your phone
for a while. And when the shutdown happens you are not
available.
Me too.  It seems to be something introduced into Bookworm between my Dec 30 and Jan 12 dist-upgrades.
(01-15-2022, 12:57 PM)treebeard Wrote: Me too.  It seems to be something introduced into Bookworm between my Dec 30 and Jan 12 dist-upgrades.
Strangely enough, the problem hasn't happened again since posting the last message.  I guess it really does help to talk about your problems!  I think that batch of updates included my first install of a 5.15 kernel (and then rebooting to use it).  I did another upgrade today, which included an update to kernel 5.15.
same problem here with mobian bookworm
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 77 41,740 10-27-2025, 10:19 AM
  cryptocurrency on mobian/pinephone biketool 35 57,764 10-08-2025, 06:21 AM
  Axolotl on PinePhone / Mobian arno_nuehm 223 272,506 06-25-2025, 01:19 PM
Last Post: anonymous
  Mobian Pinephone Notification LED biketool 2 2,438 06-07-2025, 03:19 PM
  Pinephone seems tobe using 4G data instead of Wifi data grump_fiddle_reinstall 7 4,953 02-20-2025, 02:47 PM
Last Post: puffchumpy
  How to use QR codes on Mobian Sid(unstable) Pinephone Pro biketool 1 2,323 01-02-2025, 12:47 PM
Last Post: zetabeta
  unofficial kali linux for pinephone help needed pinesmell 5 7,480 01-08-2024, 02:50 PM
Last Post: ERPlegend
  PinePhone won't boot after software update jb2000 2 3,581 03-17-2023, 07:26 AM
Wink Pinephone lost graphic during mobian system upgrade cmpin 4 4,960 03-01-2023, 04:45 PM
  Battery problem with a Pinephone keyboard and Mobian elode 2 4,270 12-22-2022, 07:10 PM
Last Post: acid andy
