Pinephone is dead (sort of)
#31
(12-31-2021, 11:55 AM)thorensjubilee Wrote: Will it "repair" the EEMC if I use it?
Afraid not, the factory test image just runs diagnostics. However even if the eMMC is not working the phone is not bricked as long as it boots off of an SD card, you could just use it that way.
(12-31-2021, 11:55 AM)thorensjubilee Wrote: Hello wibble,
Chris
It can't fix broken hardware, but unless I've missed something (always possible ;-) ) it's not been determined yet what the problem with the eMMC is. From mobian the whole eMMC should be /dev/mmcblk2 while any partitions would be /dev/mmcblk2p1 etc. Any errors accessing it should show up in the logs which you can access using journalctl.
Hello everybody,
I have just downloaded UB ports, my favourite OS, and it downloaded onto the emmc! So that's the conclusion. The reset buttom did the trick.
I would just like to give a big THANK YOU to everybody who replied.
Chris
(01-01-2022, 07:57 AM)thorensjubilee Wrote: Hello everybody,
Chris
Weird one. But well done and Happy New Year
That's great! The eMMC hardware must have been in a funny state where doing a hardware reset cleared it. Bizarre but as long as it's working now that's the main thing.
  PinePhone - boot from microSD laserpyramid 6 553 04-22-2024, 02:22 AM
Last Post: bongosunny
  pinephone virtual keyboard aular 4 346 04-10-2024, 03:45 PM
Last Post: aular
  PinePhone Doesn't Boot LED Doesn't Show Any Signs When Charging dorkydev 1 230 04-02-2024, 11:50 AM
  Are you using the Pinephone as your daily driver? jro 157 108,955 02-18-2024, 11:33 PM
Last Post: aular
  2020 PinePhone Manjaro CE EU for sale, name your price astrojuanlu 7 1,788 02-14-2024, 04:51 PM
Last Post: astrojuanlu
  pinephone is not bootble for the box. ijij 1 602 01-19-2024, 01:29 PM
Last Post: fxc
  Multiple issues with the Pinephone MTXP 12 2,352 12-28-2023, 07:55 AM
Last Post: MTXP
  pinephone repair shop shengchieh 0 494 12-26-2023, 02:42 PM
Last Post: shengchieh
  sudo nano file saving pinephone beta edition CharlesGnarley 4 1,681 12-22-2023, 03:44 PM
  Can't get Mobian on PinePhone to recognise USB-C docking bar duncan_bayne 9 6,946 12-04-2023, 02:14 AM
Last Post: Peter Gamma
