When I set SD card as /home, PP can't complete boot
I was running Bookworm with /home on the SD card, and everything was working sort of OK.
I tried to update to the 12 Dec weekly build, and all was OK until I edited /ect/fstab to make the SD card /home. After editing, repeatably, the PP will boot, and then the screen goes blank with the backlight still on. If I remove that third line from fstab it again boots normally. I can mount the SD card as /home and everything seems to be fine, but if I try to add it to the fstab to make it permanent, the boot fails/hangs/something.
I fell back on an earlier build with a 5.13 kernel, and still the exact same thing, so I'm thinking there may be something on my SD card that's causing trouble at boot?
Any ideas what might be going on? I would REALLY like to have my home back on the SD card without having to remount it every time I boot, because I'm having to boot a lot!
Pinephone beta edition, convergence model, Mobian Bookworm with Phosh.
I'm not clear on how you've mounted the SD as /home when it's running normally. Was it a full manual mount command, or did you uncomment the line in fstab then just mount /home? The second option would show the fstab line was error free.
Another question - does the SD have a copy of the working /home/<username> present so the user's configs, session data etc. is available?
I can mount the SD card with sudo mount -t ext4 /dev/mmcblk0p1 /home and it works. I'm running that way now, as I type this on the PP.  I have all the stuff in the mobian directory there that I expect.
I follow the instructions in https://wiki.mobian-project.org/doku.php...nencrypted to build the fstab entry.
The fstab line I build is modified from the first line of the current fstab:
UUID=5eb7c824-6cba-41ab-80cc-5c3d45012776    /    f2fs    defaults    0    1
to be like this:
UUID=3314869d-66e3-44ad-8dbb-7a7275b6ea64 /home    ext4    defaults    0    2
With that last line in there, the boot somehow either hangs, or delivers a blank screen, or something.
(12-22-2021, 11:30 AM)nelstomlinson Wrote: I can mount the SD card with sudo mount -t ext4 /dev/mmcblk0p1 /home and it works. I'm running that way now, as I type this on the PP.  I have all the stuff in the mobian directory there that I expect.
To mount /dev/sdx as /home during boot, perhaps this link can help something:
https://linuxhint.com/use-etc-rc-local-boot/
This is the fstab that causes it to not complete the boot, if I uncomment that last line:
mobian@mobian:~$ cat /etc/fstab
UUID=49871ada-b2ac-4162-a2bc-7ea476ac0516    /    ext4    defaults    01
UUID=199221bd-4da8-4ed5-b995-0d0781698f6a    /boot    ext4    defaults    02
#UUID=3314869d-66e3-44ad-8dbb-7a7275b6ea64    /home    ext4    defaults    0    2
This is the shell script that successfully umounts and mounts the SD card when I run it as sudo:
mobian@mobian:~$ cat /usr/bin/msd
#! /bin/bash
umount /media/mobian/3314869d-66e3-44ad-8dbb-7a7275b6ea64
mount -t ext4 /dev/mmcblk0p1 /home[
Finally, this is the uuid of the SD:
mobian@mobian:~$ sudo blkid /dev/mmcblk0p1
[sudo] password for mobian:
/dev/mmcblk0p1: UUID="3314869d-66e3-44ad-8dbb-7a7275b6ea64" BLOCK_SIZE="4096" TYPE="ext4" PARTUUID="3634a9ac-01"
  mobian installed to eMMC - how to install tow-boot grump_fiddle_reinstall 6 2,067 11-22-2023, 11:46 AM
Last Post: aLoop100o
  How to check if tow-boot is installed? jojuma 3 980 09-29-2023, 11:29 PM
  Mobian boot failed with zstd message after upgrade. Mahgue 0 648 09-01-2023, 11:29 AM
Last Post: Mahgue
  4G data on default startup / boot dcinoz 1 859 04-29-2023, 11:24 PM
Last Post: dcinoz
  PinePhone won't boot after software update jb2000 2 1,361 03-17-2023, 07:26 AM
  Boot log analyses -> GPU no regulator (mali) found freelectro 0 984 03-06-2023, 12:06 PM
Last Post: freelectro
  APN settings not working with new operator SIM card user641 1 1,052 03-01-2023, 04:43 PM
Last Post: anonymous
  boot gets stuck shortly after disk decryption vortex 8 4,073 02-13-2023, 02:11 AM
Last Post: sharase
  What does handle SD card automount? mdk 1 1,058 01-29-2023, 03:15 AM
Last Post: mdk
  [solved] Black screen at boot time mdk 0 1,026 01-13-2023, 03:33 AM
Last Post: mdk
