Mobile internet via cellular network mostly not working
(12-04-2021, 08:27 AM)Anna Wrote: For some time now (since Bookworm? Or only a few weeks? I actually don't know) I usually don't have internet access via the mobile network.
Sometimes it works, mostly it does not. A restart usually helps, but of course that's not what you want to do when you need to quickly look something up or when you or wait for a Signal/Telegram message while on the move. The problem occurs with two different providers.
Is there anything I can do?
@Anna
Have you tried using an sd card flashed with the latest release..?
If the sd card works, it could indicate a problem with your currently installed software.
If that gives the same results,   it could show a hardware or firmware fault.
Good Luck !
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
your favorite OS Team
RE: Mobile internet via cellular network mostly not working - by bcnaz - 12-05-2021, 12:03 AM
  New camera app gnome-snapshot working on trixie? vusra 4 2,769 04-11-2025, 02:53 AM
Last Post: vusra
  Calls 4G not working oliwierzgorniak 2 3,843 08-06-2024, 02:20 PM
Last Post: baptx
Exclamation The internal speaker stops working anonymous 6 5,394 01-17-2024, 05:53 PM
Last Post: anonymous
  APN settings not working with new operator SIM card user641 1 2,523 03-01-2023, 04:43 PM
  Possible Solution for Microphone Not Working Ferriah 0 2,029 02-13-2023, 01:09 PM
Last Post: Ferriah
  Not connecting to cellular network car46999 18 16,956 01-30-2023, 12:06 AM
Last Post: car46999
  Block firefix-esr-mobile-config from (re)installing itself grump_fiddle_reinstall 3 3,867 01-07-2023, 09:36 AM
Last Post: dcarvil
Exclamation No modems were found: No mobile data, no 2G anonymous 2 3,514 12-26-2022, 06:46 PM
  very slow processing of MMS received via Ting (T-Mobile) treebeard 6 6,380 12-01-2022, 09:18 AM
Last Post: traut
  Squeekboard stopped working Zebulon Walton 2 3,261 11-24-2022, 08:41 PM
