I'd like to have a Discord client on Mobian
I see that there isn't a Discord client under the Software installer nor available at the command line with apt.
Would it be possible to install the .deb directly?
If the source code needs to be ported to Mobian, are there guides for how to go about that? I'm willing to give it a try.
Thank you.
Discord is closed source, so you either need to use the browser version (which would be better anyway, since the Discord app is a massive spyware), or kiss their feet in return to make an ARM version available (and I doubt they will).
If you go for the browser version, I suggest you use Qutebrowser for that, since most other browsers are pretty much soyware, and Discord itself is very bloated too.
And Qutebrowser allows you to zoom the web app down while still being able to click everywhere without having to misclick all the time (using the "F" key).
Zooming out is necessary, because otherwise you won't see shit while using Discord on a small screen, since the desktop/web version of Discord is not a responsive app.
母語は日本語ですが、英語も喋れます(ry
Ugh, Discord siphons all kinds of data... May as well just use a Google device and skip the Linux
(04-16-2022, 06:55 AM)Hobbes42 Wrote: Ugh, Discord siphons all kinds of data... May as well just use a Google device and skip the Linux
Yeah, I don't get it, either.
*cough*pointsatsignature*cough*
Cheers,
TRS-80
Protocols, not Platforms
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 17 2,089 Today, 05:47 AM
Last Post: diederik
  Mobian repository status henrythemouse 16 8,801 04-10-2024, 10:02 AM
Last Post: diederik
  cant verify mobian image at website gnugpg penguins_rule 0 135 03-18-2024, 08:54 PM
Last Post: penguins_rule
  mobian installed to eMMC - how to install tow-boot grump_fiddle_reinstall 6 2,013 11-22-2023, 11:46 AM
Last Post: aLoop100o
  What actions needed to keep on mobian testing user641 3 1,835 09-05-2023, 06:44 AM
  Mobian boot failed with zstd message after upgrade. Mahgue 0 636 09-01-2023, 11:29 AM
Last Post: Mahgue
  how to update mobian over tor vusra 13 6,936 07-09-2023, 08:57 PM
Last Post: vusra
  opensnitch outbound firewall now works on mobian vusra 2 1,908 07-09-2023, 01:37 AM
Last Post: vusra
  Using Nativefier on PP64 with Mobian paulcarton 0 634 07-05-2023, 03:57 AM
Last Post: paulcarton
  Has anyone got briar-desktop running on mobian? vusra 5 3,036 06-19-2023, 03:02 PM
Last Post: vusra
