What do you use for voice chat on Mobian?
(08-06-2021, 03:35 PM)HLing Wrote:
(08-06-2021, 03:10 PM)ragreenburg Wrote:
(08-05-2021, 05:46 PM)HLing Wrote:
(08-03-2021, 03:27 PM)ragreenburg Wrote:
(08-03-2021, 03:01 PM)HLing Wrote: I think it did send a text to my pinephone, but it is an mms. I can see that long string of letters and numbers when I go to the terminal, but it's not decipherable as a code....
I never got mine, even as MMS, but I set it up on a different device and then used that device to set up my PinePhone. After you have a device setup you can just scan the QR code I thin
I installed it on my GPD MicroPC. There was a QR code that I tried to use the Pinephone's Megapixel to scan.  a blue outline appeared around the QR image.  I pressed the button to take the picture. Nothing happened except that I have a picture of the QR code......Sad
I believe you are supposed to scan it the other way around if I remember correctly. I pulled up the QR code on my phone and scanned it with my tablet and that worked. Or I could be misremembering.
Ah, so that assumes you have a camera on your tablet then?  I don't have one on the MicroPC, but I do have one on the P2Max.  It didn't work either. I did try to scan with my phone again, and this time there was an option to go to the URL. I chose it (on the megapixel screen) but nothing happened. My version of the Telegram-desktop doesn't have Setting - Device - ....so I think it's just an endless loop of no account.
I don't know what kind of code is embedded in your QR code, but you should probably copy the code and insert it somewhere instead of opening the URL (tap on the box around the QR code and then choose to copy). Note that on Mobian only an outdated version of Megapixels is available wich copys the code to the primary selection instead of the main clipboard. So if you use Mobian, you have to use a workaround to access the primary selection (e. g. with wl-clipboard: wl-paste --primary).
(07-24-2021, 10:11 PM)ragreenburg Wrote: My phones motherboard just stopped working so I am now forced to use the PP as a daily driver. It's been alright so far but the microphone on the phone is super staticy and it won't work with my bluetooth headset. I can listen to music but can't talk over the phone. I can't get discord on the phone and Axolotl doesn't do phone calls so what other options are there?
I've noticed sometimes the amps get set weird and I have to readjust them with alsamixer. Sometimes that can help with the static.
  Mobian image for the PinePhone Korfou 2 668 04-27-2026, 09:57 AM
Last Post: Korfou
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 80 57,413 12-24-2025, 12:11 AM
  cryptocurrency on mobian/pinephone biketool 35 67,507 10-08-2025, 06:21 AM
  Mobian MMS/SMS text problem bcnaz 16 33,380 09-15-2025, 02:42 AM
Last Post: georgegohl888
  XLibre for Mobian Hiraghm 0 2,727 06-29-2025, 12:38 PM
Last Post: Hiraghm
  Axolotl on PinePhone / Mobian arno_nuehm 223 316,642 06-25-2025, 01:19 PM
Last Post: anonymous
  VoIP account on mobian dialer j_s 0 2,437 06-15-2025, 04:19 PM
Last Post: j_s
  Mobian Pinephone Notification LED biketool 2 3,297 06-07-2025, 03:19 PM
  Vivaldi Web browser nearly native for Mobian biketool 3 3,899 05-06-2025, 02:19 AM
  mobian calamares fail merom 2 3,734 04-29-2025, 02:10 PM
Last Post: mdk
