4K@30 video output does not work properly on Pinebook Pro
Bug
I have Pinebook Pro connected to LG 27UD88-W monitor via USB-C to DisplayPort cable. I'm running Manjaro ARM 21.06 (Linux kernel 5.12) with Sway WM. The problem is that I can't run 4K @ 30Hz properly (right 1/3 of the screen is distorted). FullHD (1920 x 1080) and WQHD (2560 x 1440) works just fine. I have also tested X11 based Linux distros and the issue is the same. Anybody had luck to run 4K @ 30Hz video output on the external monitor?
This is the similiar thread, but it is closed.
I will be more than happy to provide more details if necessary.
$ dmesg | grep cdn-dp
[    5.395293] cdn-dp fec00000.dp: Direct firmware load for rockchip/dptx.bin failed with error -2
[    5.395302] cdn-dp fec00000.dp: Falling back to sysfs fallback for: rockchip/dptx.bin
[   69.610270] cdn-dp fec00000.dp: [drm:cdn_dp_request_firmware [rockchipdrm]] *ERROR* failed to request firmware: -11
[  101.919603] cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work [rockchipdrm]] Connected, not enabled. Enabling cdn
[  549.569829] cdn-dp fec00000.dp: [drm:cdn_dp_check_sink_connection [rockchipdrm]] *ERROR* Get sink capability timed out
[  549.570998] cdn-dp fec00000.dp: [drm:cdn_dp_encoder_enable [rockchipdrm]] *ERROR* Failed to enable encoder -19
  Boot Order in Pinebook Pro food 12 13,181 05-25-2026, 08:28 AM
Last Post: finmark
  Window Maker Live for Pinebook Pro vajak 9 3,335 05-20-2026, 06:55 AM
Last Post: vajak
  Upgrading Armbian from v24.2.1 gnome, breaks pinebook pro Sb2024 1 12,850 08-09-2025, 06:53 AM
Last Post: Sb2024
  PinePhone keyboard not registering input properly Feemphynead 0 2,106 04-25-2025, 03:37 AM
Last Post: Feemphynead
  Inexpected reboot during watching youtube video regivanx 1 2,734 10-19-2024, 06:02 AM
  Pinebook pro won't boot after bootloader installation jwensouls 4 6,679 08-21-2024, 04:17 AM
  (xorg) Video driver? falken 2 3,743 07-03-2024, 12:01 PM
Last Post: falken
  [Pinebook Pro/Mobian/XFCE4] can fix touch or screen in greeter not both SynthGal 0 3,712 05-31-2024, 09:42 AM
Last Post: SynthGal
  Debian on Pinebook Pro u974615 7 10,222 03-31-2024, 10:11 AM
Last Post: u974615
  Pinebook Pro upgrading from the factory image yamsoup 12 14,081 02-22-2024, 04:02 PM
