Update-rc.d for Mobian
Hi, I'm trying to use this command (update-rc.d) to add a script to the startup but Kings's Cross can't find it. Is it possible to install this command? Thanks!
What I've been doing since systemd took over the init process on Debian is to enable the traditional /etc/rc.local startup file. This makes it easy to add your own commands and scripts to system startup.
https://www.troublenow.org/752/debian-10-add-rc-local/
(06-27-2021, 08:02 AM)Zebulon Walton Wrote: What I've been doing since systemd took over the init process on Debian is to enable the traditional /etc/rc.local startup file. This makes it easy to add your own commands and scripts to system startup.
Nice! I'll try that tonight. Thats a very helpful link. Thanks for your help, have a nice day!
  Mobian repository status henrythemouse 16 8,600 04-10-2024, 10:02 AM
Last Post: diederik
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 15 1,869 03-25-2024, 09:07 AM
Last Post: anonymous
  cant verify mobian image at website gnugpg penguins_rule 0 120 03-18-2024, 08:54 PM
Last Post: penguins_rule
  mobian installed to eMMC - how to install tow-boot grump_fiddle_reinstall 6 1,912 11-22-2023, 11:46 AM
Last Post: aLoop100o
  What actions needed to keep on mobian testing user641 3 1,779 09-05-2023, 06:44 AM
  Mobian boot failed with zstd message after upgrade. Mahgue 0 622 09-01-2023, 11:29 AM
Last Post: Mahgue
  how to update mobian over tor vusra 13 6,826 07-09-2023, 08:57 PM
Last Post: vusra
  opensnitch outbound firewall now works on mobian vusra 2 1,882 07-09-2023, 01:37 AM
Last Post: vusra
  Using Nativefier on PP64 with Mobian paulcarton 0 621 07-05-2023, 03:57 AM
Last Post: paulcarton
  Has anyone got briar-desktop running on mobian? vusra 5 2,982 06-19-2023, 03:02 PM
Last Post: vusra
