Battery doesn't charge
Interesting problem.
Computer runs but... dies frequently
Plugged into power (barrel connector); green power light on; battery charging (0%)
/sys/class/power_supply/cw2015-battery
voltage_now 3723000
capacity 0
charge_counter 1
status Charging
current_now 0
Battery problem or charger problem?... or ?
Does the red led beside barrel socket light?
If you have an inline usb V-A meter that would be helpful
If the battery is truly that low, that is normal behavior (for the controller),
a flat battery SHOULD be charged slowly until it is at 5%
Try charging overnight (pbp off)
Try charging thru usb C, also overnight (not at same time as barrel)
If the battery level is truly 0%, charging by USB-C overnight, with the power off, and without the barrel charger, might be your only means to get the battery charged. I don't know why. But this is what's been reported here, often.
After that, charge with either charger.
It is quite normal for the charger to not keep up during normal usage. Depending on your operating system, charging during usage might not even be possible. Some operating systems don't throttle the CPUs by default.
Thanks for these suggestions.
I disconnected and bypassed the battery using the installed bypass cables and it works fine for now.
Before, the red light next to the barrel jack was flashing. The battery was not charging.
I'll try reconnecting the battery and charging it with power off through USB-C tonight.
https://www.ti.com/lit/ds/symlink/bq2417...52FBQ24171
Page 5,, STAT
Battery is charged!
I took the advice and charged with the USB-C connector overnight with the unit off and this am the battery is at 100%
Hopefully this cured the problem.
Thanks very much to all of you.
  Bad replacement battery? chris88233 3 255 02-19-2024, 04:59 PM
  red charge light goes out gilwood 19 1,007 02-10-2024, 10:28 AM
Last Post: gilwood
  Bypassing the Battery gilwood 0 194 02-01-2024, 10:45 AM
Last Post: gilwood
  PBPro Battery specification Perl6_user 3 457 12-26-2023, 04:28 PM
Last Post: DrYak
  Replacement battery for PineBook Pro DrYak 3 955 11-07-2023, 10:09 AM
Last Post: DrYak
  Battery replacement mjc 2 2,793 09-26-2023, 01:08 AM
Last Post: david-lechner
  Battery drain when off srs5694 1 959 03-24-2023, 06:05 PM
Question Battery stops charging and NVMe and other media disconnect randomly Eey0zu6O 4 4,633 07-09-2021, 08:45 PM
Last Post: moonwalkers
Question Powering off & won't power back on w/o battery disconnect jimsurvak 5 5,273 11-10-2020, 08:42 PM
  Charge indicator LED blinking mrozema@gmail.com 5 7,740 10-27-2020, 09:29 AM
Last Post: Nick_dnepr
