Pinephone
Mobian OS
Debian Gnu/Linux bullseye/sid
64-bit
Gnome Version 3.38.4
Wayland
I have Mobian installed on my Pinephone and it is not updating or allowing me to update it via software app. When trying to refresh it says it cannot get it. If I can not update it, does it mean I will have to do a clean install of Mobian every time a new version comes out? I have not updated it since around May 5th of 2021.
have you tried to ssh into the phone and run sudo apt update && sudo apt upgrade?
08-20-2021, 08:26 PM
(This post was last modified: 08-20-2021, 08:36 PM by FOSSagent0.
Edit Reason: need to add info
I've had my phone shelved away for a bit as it was not daily driver material. I had updated using the King's Cross terminal app but I'm unsure what to do with the configuration windows that pop up in the terminal. Has things been changed for the last updates? As for future updates available I'm not sure if I should use the software app or King's Cross.
edit: While I returned to using the Pinephone after it was shelved away for a bit, it was acting erratically as if it was corrupted, it was glitchy turning the screen to a blank black screen. After doing a clean install of a stable release. I've updated it. I did update it today using King's Cross a few minutes ago. I do wonder if the Software app has been fixed since then. So far it seems like I'm still not receiving any text messages.
Have you tried another operating system from an sd card, just to compare your own results ?
When mine will not update through the GUI updates, I try again in 24 hours, 99% of the time it will update after the wait.
BUT If it still will not update, then I flash my sd card to the latest release.
I only have my contacts loaded in my phone, so it is not a big deal for me to just install a new system,
> I do understand if someone has a lot of stuff saved or downloaded, they may prefer to FIX the system instead.
My contribution to better software is donating $$ to the team that can actually improve the software.
Meanwhile, if I must flash a few sd cards to make my phone work out here in the wild world, so be it.
LINUX = CHOICES
**BCnAZ**
Donate to $upport
your favorite OS Team
My Daily driver is on a nightly build from July, plus updates, have another PMOS phone has the current tonights release.
Tonight's release seems great, except the onboard software store is not loading,
*** locked screen notifications is working ! ***
