I'm unable to open downloaded programs
(06-08-2021, 11:16 AM)hayduke Wrote: Thanks Carlos. That helps a lot. I can't figure out why I'm having so much trouble installing my printer. I've been using linux since 2008 and have never had this problem before. All I want to do is hook up to my printer.
Do you have CUPS installed?  Unlike pretty much every linux distro I've used, the default Manjaro doesn't have it.  So:
pamac install cups
Then you've got to start it up:
sudo systemctl enable --now cups.service
sudo systemctl enable --now cups.socket
sudo systemctl enable --now cups.path
Point a web browser to localhost:631 and you'll get a clunky but serviceable web-based printer management interface.
Is your printer directly connected or network?  Setting up a generic printer (just choose Generic for the type) seemed to work pretty well for me.
RE: I'm unable to open downloaded programs - by carlosqueso - 06-08-2021, 06:51 PM
  Unable to Boot anything (emmc or SDcard) line72 5 1,997 01-17-2023, 12:07 PM
Last Post: nfms
  Unable to boot from emmc after flashing it rfm83 3 1,764 11-08-2022, 10:59 PM
Last Post: rfm83
  cannot boot SD card : "unable to select a mode" alchemist 0 2,123 06-18-2021, 02:03 AM
Last Post: alchemist
  Finding and adding new programs/apps James Good 3 3,435 02-27-2021, 05:41 PM
Last Post: User 17828
  Why can't Pinebook Pro have TOR browser and other programs? SanjevR 7 7,682 12-08-2020, 03:52 PM
Last Post: nas
  Problem with Pinebook Pro unable to read mmc1 murda 2 3,492 11-22-2020, 03:08 PM
  Unable to connect to Wi-Fi with 802.11r enabled lrussell887 1 2,819 10-28-2020, 02:00 PM
Last Post: mammbo3
  Another Newb Unable to Boot From microSD JimmyJazz1971 3 4,014 10-26-2020, 03:48 AM
Last Post: JimmyJazz1971
  thanks for a solid open source solution anhinga 0 2,014 10-06-2020, 03:47 AM
Last Post: anhinga
  Unable to mount NVME (PineBook Pro) WallStreet 4 6,792 09-13-2020, 11:16 PM
Last Post: Phillip Bell
