Centos 8 Stream on Rock64
So I followed along the guide to install CentOS 7 referenced on the Wiki (and noted on the thread here: https://forum.pine64.org/showthread.php?...&pid=95685 and the guide on the developer's site here: https://project31.github.io/pine64/), and decided to give upgrading to CentOS 8 and then switching to Stream a try.
I followed a few guides online (specifically here https://www.tecmint.com/upgrade-centos-7-to-centos-8/ and here https://linux.web.cern.ch/centos8/docs/migration/), and with a tad extra fiddling to handle the kernel version, I was able to get fully updated and now am booting into CentOS stream!
My question is that upgrading 7 - 8 isn't technically supported, so I would like to try making an updated image for Stream 8.
The Project31 site has some info linking to it's inspiring project, which mentions taking the AArch64 image and a booting Armbian image and swapping out the rootfs bits while preserving the the /boot, /lib/modules, and /lib/firmware (here: https://github.com/umiddelb/aarch64/wiki...ch64-board)
When I try to follow up on this, I cannot seem to figure out how to take the images available on the CentOS site and extract the rootfs.... Can anyone point me in the right direction?
Thank you for your help, and your patience!
Have you tried the procedure that works with CentOS 7?
https://www.thegeekdiary.com/centos-rhel...itview-it/
it doesn't get happy
it doesn't get sad
it just runs programs
  Xen hypervisor on Rock64 tumbleweed 6 9,684 Yesterday, 09:25 AM
Last Post: darkfader
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 9 15,793 07-20-2025, 01:00 PM
  Rock64 - not booting after Armbian update helpmerock 6 3,672 03-27-2025, 08:26 AM
  can rock64 4gb ram run entirely on free software? heocb 1 2,359 01-07-2025, 05:47 AM
  Upgrading ancient Rock64 timxjr1300 1 2,487 11-26-2024, 09:47 AM
Last Post: dmitrymyadzelets
  arch rock64 does not boot nemnob 1 3,517 09-20-2024, 11:18 AM
Last Post: AwU2HBg
  DietPi OS for ROCK64 MichaIng 42 68,658 09-01-2024, 06:43 AM
Last Post: RaymondDay
Smile First Lakka image for Rock64! Luke 47 100,236 09-01-2024, 06:05 AM
  Rock64 v2 - did not work song / audio sqw200zu 2 4,437 03-14-2024, 03:09 AM
  Rock64 won't boot dstallmo 0 2,608 12-27-2023, 10:34 AM
Last Post: dstallmo
