Remix OS
#61
(04-21-2016, 01:09 PM)dwmzhou Wrote: So if it is not work for you, you might want to try a different switch.
It not only sounds so, it is. Have already tried several routers and switches, but no success yet.
Thanks for clarifying.
Gesendet von meinem XT1032 mit Tapatalk
Still a linux newbie with several EEE-PCs, PI's, LattePanda and some Desktops/Laptops running Win10. Now also proudly using Pine64+ 2GB and gigabit LAN
It's working perfectly for me on the 2 gig version. No issues with ethernet speeds either.
(04-21-2016, 09:38 PM)crisra13 Wrote: It's working perfectly for me on the 2 gig version. No issues with ethernet speeds either.
What speed are you using and is it really full GB speed if available?
Gesendet von meinem K00L mit Tapatalk
Let me check tonight (US EST) and get back to you.
(04-21-2016, 12:23 PM)androsch Wrote:
(04-21-2016, 11:32 AM)dwmzhou Wrote: I have a 2GB version of Pine64 with Gigabit Ethernet on it. Now the network is working with the last Remix image 0415_Beta!  Smile  It took me a couple of tries to make it work though. My network switch is a 100 Mb Netgear which works fine for all my other PCs. But it doesn't work for my Pine64. So I bypassed the switch and to my surprise it worked right away.
Do you have gb speed or 100mbits? Not clear to me, cause gb on a 100mbit switch obviously wont work, just with reduced speed of course. Im interested in somebody having real gb speed for the board (on a 100mbit port works fine for me but is not gb like provided)...
androsch, right now mine is bypassing my switch and directly connect to my home router which only has 100mbits ports. So it is a Gigabit card running on a reduced speed. (My internet speed is only 10mbits down). I have not tried my Pine64 on a Gigabit network switch yet. But now I learned the NIC on Pine64 can be sensitive to the network switch (I know this sounds weird). So if it is not work for you, you might want to try a different switch.
Remix OS 2.0 Image Release 20160415 Beta
I use speed.net app tested my switch 100M , the test is 90M UP / 90M Down Wink
If I am wrong please correct my content , thank !
1. Use Pine64 Running Ubuntu 16.04 Web Server ( LAMP )
2. Use Pine64 Running Official Android 6  for Media player
3. Use Pine64 Running Volumio Digital Audio Player
Thanks, but thats not the question. With a 100mbit switch i also have about 96mbits, but i'm interested to use the GB speed which doesn't work for me at the moment.
So i'm looking for someone also having the 64+ model and having GB lan to check his settings compared to mine...
Regarding to longsleep his board is using the GB speed and mine doesnt, even using the same kernel....
Hello everybody. I just got my Pine A64 2GB. I downloaded the latest remis os from the wiki and burned it with phoenix software. I plugged the microSd into the Pine A64 and powered it. All i got is a black screen. Do you have any idea how to solve that problem?
How long have you waited before you've stopped it?
Which microSD card are you using?
My forum topics:
• Create a WiFi hotspot on Debian 8
• Turn your Pine64 into a music server with mpd
• Adjust brightness of LCD on Armbian Desktop with 1 click
• My cases for Pine64 (acryl, lego & wood)
• Pine 64 - DACH - Facebook page for german-speaking Pine64-fans.
(04-23-2016, 09:22 AM)JulianM Wrote: How long have you waited before you've stopped it?
I'm using a micro Sd by Kingston 16 GB class 10. I waited about 30 minutes.
After serveral try now it boot but now i stucked on RemixOs logo
Frankly, both imgs are a mess. I have tried the Phoenix card and dd img, and neither work for me. I tried different cards - even bought a brand new one to eliminate all potential problems. And nothing seems to work. I have no problem getting the Ubuntu img working however....
  sourround sound - Remix MrSarkasmus 0 4,226 10-05-2018, 05:05 AM
Last Post: MrSarkasmus
Star Remix OS 2.0 Image Release 20160718 tllim 25 55,371 08-30-2018, 01:21 PM
Last Post: Idemdesign
  Remix os os 64bits ?? Matroxplay 1 5,893 07-14-2018, 11:48 AM
Question Nginx proxy on Remix OS -- possible? mitchmitchell 1 6,352 05-29-2017, 02:45 AM
Question Remix OS 2.0 [20170105] Waaaa??? veronicasmithen03 1 6,229 05-29-2017, 02:42 AM
  REMix OS Boots and then blank Screen Michaelrowe01 6 22,953 04-17-2017, 04:20 AM
Last Post: simplexdan
  Stuck at Remix OS logo leongzhi 9 29,396 12-21-2016, 08:09 AM
Last Post: Michaelrowe01
Exclamation LCD TOUCH SCREEN PANEL support in Remix? mcfly777 4 11,571 12-19-2016, 07:49 PM
Last Post: Toriless
  Guest Account in Remix OS cannot Get Internet Connection deniyulianti 1 5,646 10-15-2016, 07:16 AM
Last Post: MarkHaysHarris777
  No microphone input in Remix xtcrefugee 3 12,617 08-19-2016, 06:24 PM
Last Post: jkmooney
