WiFi not working with PCIe SSD installed
I have a rockpro64, if I do not have the PCIe card installed the wifi works, but if PCIe is installed I can see the SSD on the PCIe card but the standard WiFi module is not available.
Must be some sort of conflict during the boot process. Have tried several lINUX versions mrfixit, twisted OS, latest Debian all do the same.
Also noted that with latest Twisted OS standard USB not working only USB c
  RK3399 PCIe enumeration jhadd 0 2,385 01-31-2024, 08:56 AM
Last Post: jhadd
  Can RockPRO64 support PCIe Endpoint? andrewg132 3 5,708 10-14-2022, 06:24 AM
Last Post: rwk-
  bullseye 11.3 WiFi drivers moserwi 0 2,559 03-28-2022, 02:01 PM
Last Post: moserwi
  prevent bluetooth from loading (manjaro, no wifi/bt card installed) flounder 0 2,300 02-17-2022, 12:10 PM
Last Post: flounder
  No PCIe controller detected... Limhes 1 3,101 11-23-2021, 06:23 AM
Last Post: Limhes
  Using the PCIe slot of ROCKPro64 as EndPoint mode nonoriri 1 3,357 11-20-2021, 10:53 AM
Last Post: fire219
  HBA Card working on Aufan's builds but not in debian, armbian or dietpi charsi 1 3,796 10-29-2021, 11:15 AM
Last Post: TRS-80
  WORKING: GPU-accelerated Widevine Chromium for Ubuntu 64 twilite 0 3,091 09-13-2021, 11:02 AM
Last Post: twilite
  Power supply underpowered for Rockpro64, deficient PCIe SATA card, or something else? daffy 8 11,701 05-20-2021, 10:04 PM
Last Post: t4_4t
  Wifi on Manjaro User 19517 0 2,863 09-14-2020, 06:53 PM
Last Post: User 19517
