Pine power firmware
Hi
There are some elements of the display behaviour on the pine power I dislike. Is the firmware opensource so that I can fix it, please?
What do you dislike?
The wiki does not document any firmware, just an image showing the rear of the LCD panel -- there are two unmarked ICs (U4 and U5). I do not know if these are re-programmable it may be a difficult process even assuming the programming could be re-applied (they may even be programmable only once).
The screen power down behaviour mostly - if the PSU is on, I want the screen to stay in unless I press the screen off button, and if the screen is off then I want the screen off button to turn it back on.
Currently I have to physically look at the power switch to tell if it is on, and the screen sometimes comes on when wireless charging and sometimes doesn't
  Question about firmware updates on Pinecil V2 helengrace 1 450 10-16-2025, 10:41 PM
Lightbulb Product idea: Pinebank, 18650 multifunction power bank/speaker/light/etc cowsay 0 258 10-03-2025, 11:35 AM
Last Post: cowsay
  Pine.org very poor review rma00 9 7,997 07-07-2025, 12:06 PM
Last Post: dachalife
  Optimizing Power Management on PinePhone with PostmarketOS ZaraAbbas 0 2,177 05-27-2025, 01:49 AM
Last Post: ZaraAbbas
  Replacement international plugs for 65W GaN Pine Power Cadair 1 2,370 05-20-2025, 10:20 PM
  Plans for higher Power PinePowers PMARC14 1 3,288 04-08-2025, 08:31 PM
Last Post: colajuices
  Pine Desktop PowerSupply wont power on BSharp 6 5,860 01-07-2025, 08:04 AM
Last Post: skare
  Help with high voltage power supply setup for electrospinning? namarang 3 3,858 12-11-2024, 09:47 PM
Last Post: NovaSpindle_X
  What about a Pine digital audio player? ClairelyClaire 7 7,189 12-05-2024, 09:06 PM
  Pinebuds Pro Sound Firmware Update deMangler 0 1,518 05-12-2024, 06:14 AM
Last Post: deMangler
