Cant update and upgrade mobian.
Hello , I have problem.
I cant update and upgrade Mobian.
In terminal write
Reading package lists... Error!
E: flAbsPath on /var/lib/dpkg/status failed - realpath (2: No such file or directory)
E: Could not open file  - open (2: No such file or directory)
E: Problem opening
E: The package lists or status file could not be parsed or opened.
is it a fresh install?
(05-04-2021, 02:21 PM)vongillus Wrote: Hello,
No, I install about 1,5 month ago.
You should be able to refresh the apt lists by:
1 Make a backup of your apt lists
sudo cp -R /var/lib/apt/lists/* ~/lists/
2 Remove apt lists
sudo rm -R /var/lib/apt/lists/*
3 Repopulate
sudo apt-get update
Cheers!
(05-04-2021, 09:16 PM)MtnSk8 Wrote: You should be able to refresh the apt lists by:
2 Remove apt lists
3 Repopulate
sudo apt-get update
Cheers!
Thanks.
(05-04-2021, 02:13 PM)mode80 Wrote: Hello , I have problem.
In terminal write
E: Problem opening
Be aware, there was a defect in the boot partition around the time frame you did your installation where you would run out of space and no longer be able to update. Sooner or later you may need to do a fresh installation to fix the problem. Follow the blog. https://blog.mobian-project.org/posts/20...021-03-17/
  What do you use for voice chat on Mobian? ragreenburg 6 243 9 hours ago
Last Post: ragreenburg
  Mobian repository status henrythemouse 5 405 Yesterday, 04:23 AM
  Pure Maps GPS on Pinephone Mobian godzillest 3 157 Yesterday, 03:07 AM
Last Post: mouffa
  When to dist-upgrade vs when to reinstall? DrPlamsa 5 105 08-02-2021, 06:23 PM
Last Post: bcnaz
  Cannot upgrade AndyM 1 94 07-31-2021, 08:51 AM
Last Post: nelstomlinson
  Keyboard stopped working on disk encryption screen on Mobian after update cowsay 0 52 07-28-2021, 05:46 PM
Last Post: cowsay
  Wipe function on mobian? Wahtone 5 362 07-28-2021, 06:18 AM
  Axolotl on PinePhone / Mobian arno_nuehm 105 28,220 07-23-2021, 01:20 PM
  firefox-esr stopped working after June 18 update HLing 17 1,896 07-21-2021, 02:40 PM
Last Post: dante404
  Dark theme (on Mobian)? TRS-80 6 358 07-14-2021, 01:35 PM
