SD Card Mounting /formating (Manjaro, Plasma Mobile OS)
Is there a app to mount and format the sd card? I was going into the Discover app to install gnome disks but Im not sure what is the best one suited for the Manjaro on Plasma Mobile OS.
(04-22-2021, 05:37 PM)FOSSagent0 Wrote: Is there a app to mount and format the sd card?
Not sure about formatting, but for mounting open the Index file manager, open left menu, navigate to the sd card item and just open it. It gets mounted on could be opened afterwards.
Its just not detecting and mounting my sd card. Only does so when I use gnome disks, but even then I cant access it from the os.
(04-27-2021, 03:24 AM)FOSSagent0 Wrote: Its just not detecting and mounting my sd card. Only does so when I use gnome disks, but even then I cant access it from the os.
Unsupported filesystem on your card?
  manjaro-pinephone / plasma-mobile-dev: Update broken Uturn 4 91 4 hours ago
Last Post: gamerminstrel
  xmpp&jabber client for Manjaro Plasma mobile acrux 9 1,044 Yesterday, 06:18 AM
Last Post: acrux
  Plasma Mobile telephony broken? Testing / Unstable dcinoz 9 983 06-16-2021, 03:20 AM
Last Post: mouffa
  Plasma Mobile "stable" currently broken acrux 14 448 06-15-2021, 06:43 AM
Last Post: acrux
  Cannot run onionshare-gui on pp manjaro plasma scott_VYuCAbn3k1NFK 0 61 06-12-2021, 11:07 PM
Last Post: scott_VYuCAbn3k1NFK
  User Interface (Plasma Mobile) Queries dgiffin 1 75 06-12-2021, 06:24 PM
Last Post: ryo
  Manjaro phosh annoying problems and a bit of usage experience Nick_dnepr 7 437 06-09-2021, 10:04 PM
Last Post: ryo
  Manjaro (Plasma OS) bugs/ issues FOSSagent0 24 3,613 06-01-2021, 06:56 AM
Last Post: acrux
  Can i install 16 different distros apart from the default manjaro? temp0rary 4 268 05-28-2021, 03:55 PM
Last Post: temp0rary
  Black Screen on PinePhone with Manjaro Juron 5 316 05-27-2021, 07:13 AM
Last Post: dcinoz
