erase spi flash
Question
大家好,我只是想将pinebook pro恢复为出厂默认设置,并且想擦除闪存,所以找到了以下命令:
flash_erase / dev / mtd0 0 0
我想知道的是,仅运行上面的命令即可将spi flash擦除为默认值?
如果有人知道,请告诉我。
谢谢。
Hi every, I wanna konw the command "flash_erase /dev/mtd0 0 0" is erase the spi to factory defsult?
After I run this command "flash_erase /dev/mtd0 0 0" and do not flash ang "spiflash.bin" to /dev/mtd0, then reboot form the sd card will be ok ?
Or after flash_erase /dev/mtd0 must be flash a new spiflash to /dev/mtd0  (erase spi flash cannot boot normally) ?
if anyone knows, tell me please, thanks.
This should help: https://wiki.pine64.org/wiki/Pinebook_Pr...ut_the_SPI
(as a side note, i've merged your duplicate post here, and removed the other.)
  U-Boot with direct NVMe boot support for eMMC/SPI Flash pcm720 119 103,598 06-24-2021, 11:59 AM
Last Post: sepp
  Booting to sdcard stopped working after emmc flash techiedog 3 1,259 12-31-2020, 06:30 PM
Last Post: Anarethos
  Flash non-bootable eMMC? midnightcheese 2 754 12-24-2020, 08:01 AM
Last Post: midnightcheese
  U-Boot on SPI flash - discussion Arwen 20 8,567 09-16-2020, 08:20 AM
Last Post: hmuller
  Am I supposed to flash keyboard firmware and u-boot imgs? superkazuya 4 2,400 09-02-2020, 04:12 AM
Last Post: pfeerick
  How to flash the emmc when it has Chromium on it? U47 3 1,659 07-10-2020, 10:07 AM
Last Post: U47
  emmc image will not flash Uturn 10 4,017 04-12-2020, 06:38 PM
Last Post: D4RK
  The usage/access of the SPI flash aaspectre 2 1,463 01-06-2020, 08:14 AM
Last Post: aaspectre
  Uses for SPI Flash NoraCodes 36 16,154 10-21-2019, 08:07 PM
Last Post: z4v4l
