How to get audio & HW encoding working?
I have been trying to make hardware encoding and audio work on the PineCube under Armbian, but it does not appear that either is supported. For hardware encoding all gstreamer plugins and similar seem to rely on a 'cedarx' device which doesn't exist, and similarly no audio device exists in the tree either, even though the audio codec for the V3/V3s/S3 SoCs is supposed to be supported since kernel 4.12.
Is there a way to make these features work under Armbian, or are there alternatives that may work better?
Hello, I am in the same.
to activate audio just add the codec node with h3 compatible, since v3 needs changes (nixos).
regarding video acceleration I am trying with ffmpeg v4l2 request from libreelec
(04-07-2021, 08:38 AM)JuanEsf Wrote: Hello, I am in the same.
How does one add a codec node? Thanks!
Looking forward to updates on the video acceleration Smile
