After update in Ubuntu bionic mate system crashed
I have Pinebook Pro and  I just succesfully flashed bionic-mate-pinebookpro-0.9.14-1159-armhf on emmc. But when I update system with the Software Updater and restart the PC, after restart it will stop on booting screen and this screen flashes and nothing happens, the system will not load. The system will not load even if I restart it a second time.
Before, I thought it was this error message on picture 1.png, but regardless of whether I chose keep or replace every time it turned out the same.
I made the flash with the same system on flashed sd card, I flashed with balena etcher program and I flashed the system successfully. The same problem occurred when I installed the updates of this system on the sd card, until i did it all worked fine.
Thank you in advance for any answers.
PS: Sorry for my english.
Update!: I tried to flashed older version Ubuntu mate - bionic-mate-pinebookpro-0.8.3-1141-armhf.img.xz stable. But when I do it, the system cannot start and from SD card (0.8.3 version too) either.
When I turn on charged notebook, there are no flashing lights and I don't see anything, but in while I hear ubuntu login screen sound. And nothing else happened and that's all. I feel warm procesor too.
I don't know what to do.
Thanks for any help.
Exactly same Problem for me.
Have you found a workaround?
(03-26-2021, 08:06 AM)Zeronius Wrote: Exactly same Problem for me.
No, I just made it worse. If you want to use it on daily base, you can boot from SD card and don't update. I done this before then notebook stopped responding completely.
  what is the magic dd incantation to copy the system from the sd card to the emmc? geokon 14 263 4 hours ago
  Manjaro PBP stable update 2022-06-19 bricked wpeckham 2 343 06-30-2022, 10:03 PM
Last Post: wangyukunshan
  PBP won’t boot from eMMC after Debian update / Tow-Boot installer won’t boot from SD Pino64 21 1,897 05-12-2022, 05:00 AM
Last Post: Pino64
  Is anyone successfully running guix system on PBP bluekeys 6 3,706 01-20-2022, 03:06 PM
Last Post: bluekeys
  RAM deficiency after recent large Manjaro update? stozi 1 805 11-12-2021, 06:19 AM
Last Post: maxjrh
Question Can't boot any operating system other than Fedora after following the nullr0ute guide TDC_PBP 1 1,298 10-09-2021, 07:35 PM
Last Post: TangoZuluTango
  Manjaro [ARM Stable Update] 2021-07-23 issues Bocanila 0 864 07-24-2021, 09:09 AM
Last Post: Bocanila
  Manjaro Dim Display (Brightness 40%) After Every System Reboot runlinux.run 2 1,937 02-15-2021, 07:04 PM
Last Post: MtnSk8
  Ubuntu Installation on PBP narinderpal10 5 3,523 12-18-2020, 12:22 PM
Last Post: narinderpal10
  Ubuntu MATE 18.04 Can't boot after update hankg 2 2,022 12-15-2020, 01:53 AM
Last Post: BryanF
