HowTo: Get a passcode from DUO Mobile working on the Pinephone
Hey All,
I was forced to use Duo Mobile to use with my work, and I wanted to share a couple of experiences to help anyone else that may have this issue too. First, DUO now supports WebAuthn, I had to ask my IT department to get it to work. This will allow you to use a Yubikey (or other U2F device) on Firefox (as normally it is Chrome only). I just ordered a USB-C Yubikey as well, so I am curious to see if I can get that working on the Pinephone.
I was also successful in getting a passcode working with Gnome Authenticator, thus not needing the DUO mobile app (for those who don't have to use DUO, the "official" way to get a passcode working is to use their app, which is an Andriod/iOS app only. It does not natively support using third party apps, and I suspect that is by design). There is a python script to get it working:
https://github.com/kop316/duo-cli
You can use just the python script only you so choose, but you can also export the secret to your favorite 2fa app (like Gnome-authenticator). Use the
./duo_export.py
script to export your secret. Note that it uses HOTP, do you have to incriment it at every log in.
As a quick note, look at all of the "Data" in duo_activate.py , and make sure they are reasonable values too. I can only assume they have those values to check them.
(02-22-2021, 12:27 PM)kop316 Wrote: Hey All,
./duo_export.py
github url 404
(01-16-2022, 03:07 PM)transfer76 Wrote: github url 404
code moved to gitlab:
https://gitlab.com/kop316/duo-cli
  baremetal via Zig on PinePhone - JumpDrive help please WhiteHexagon 0 33 Yesterday, 05:33 AM
Last Post: WhiteHexagon
  Movuan distribution for PinePhone merom 4 943 04-07-2025, 12:32 AM
  Latest firmware for PinePhone modem! Subsentient 105 173,821 02-02-2025, 08:47 PM
Last Post: bacydentir85
  Slarm64 on PinePhone [Unofficial Slackware ARM - 64 bit] acid andy 40 42,715 12-28-2024, 12:19 AM
  Office applications for the Pinephone Peter Gamma 2 1,395 09-05-2024, 09:22 AM
Last Post: Peter Gamma
  Struggle to install LibreOffice on the PinePhone Peter Gamma 50 46,490 07-26-2024, 10:35 PM
  Why does Pine64 sabotage office on the Pinephone? Peter Gamma 5 2,395 07-04-2024, 07:34 AM
  Which word processor to choose for the Pinephone? Peter Gamma 16 9,363 06-22-2024, 07:28 AM
  Samba share on the Pinephone? Peter Gamma 0 1,111 06-16-2024, 10:26 PM
  Possible Free Backup Carrier for PinePhone PineFone 0 1,042 06-13-2024, 03:45 PM
Last Post: PineFone
