Plasma mobile email client
So I recently wandered over to Manjaro Plasma Mobile from Mobian Phosh, and Plasma seems to be working quite well. All the basics are there -- except, unless I'm missing something -- an email client.
Mobian has Geary; is there anything that someone can recommend for my Plasma pleasure?
Thanks in advance!
I saw some upstream chatter about porting Kube over to Plasma Mobile (but imo it's definitely not usable in its current state with the touchscreen - needs a mouse).
I personally still use geary-mobile on Plasma Mobile
sudo pacman -S geary-mobile
With geary, once you set up an email account, you might experience the app displaying a Gtk error dialog and then crashing at startup (the error quickly disappears). It's most likely complaining about being unable to open the keyring because gnome-keyring-daemon isn't started by KDE. To fix this, start gnome-keyring-daemon at the console (trigger it with startup scripts, as you desire):
gnome-keyring-daemon -r -d
what about Dekko?
(02-17-2021, 04:51 AM)paju1986 Wrote: what about Dekko?
Is this available on manjaro? It looks pretty decent and mobile friendly.. Work with gmail?
Is dekko available for manjaro?
(02-27-2021, 04:56 AM)gibbz Wrote: Is dekko available for manjaro?
That's what I thought when I saw the KDE bug about it; unfortunately it looks like out of those three listed (Dekko, Kube and Kirigami), only Kube is available and it doesn't seem scale (or even work) all too well. If anyone manages to get good results out of it, let us know.
Are you talking about this Dekko?
https://gitlab.com/dekkoproject/dekko (oops, sorry, just now read your link, and indeed we're talking about the same software)
I think the original Dekko is no longer being developed. I used its fork/rewrite Dekko2 on Ubuntu Touch for about a year until last September. It is still not at feature parity with the original Dekko, and missing a crucial functionality to make it a truly usable email client: integration with contacts. There is no contact book in Dekko2, and it only partially integrate with the system's contacts. Sending an email to a single contact from the Contacts app works, but if you want to add other recipients to the email, you have to enter them manually or laboriously copy from the Contacts app and paste in Dekko2.
(02-16-2021, 05:49 PM)vkraven Wrote: I saw some upstream chatter about porting Kube over to Plasma Mobile (but imo it's definitely not usable in its current state with the touchscreen - needs a mouse).
To me it seems that the Kube project has been unfortunately abandoned, before kube became ready for use, even on the desktop. When you look at the repository statistics, you see that any significant level of activity ends by February 2021. And even before that, activity has been rather low from October 2018 on.
There has been started a project Pelikan, but it seems that it is also stalled... Sad
My experience with Manjaro PlaMo: https://forum.pine64.org/showthread.php?tid=15300
I'm using Geary too on both Phosh and Plamo (and i3 counting my desktop and laptop).
I tried Claws before, which performance wise works much better, but doesn't scale at all.
I'd stay away from almost all the Kirigami apps for now, simply because they're just new and not ready yet for daily use.
And KDE has this strange habit of releasing almost entirely not functional software at first, and then take a few months or years (depending on the scale of course) to turn them into AAA premium grade software, but available for free.
母語は日本語ですが、英語も喋れます(ry
  Pinephone with KDE plasma - Battery drain when phone is not used Daniello 1 306 07-03-2024, 08:38 PM
  what is wrong with KDE plasma beta15 RC4? Uturn 8 2,691 10-02-2023, 05:07 AM
Last Post: Uturn
Exclamation My short experience with Manjaro Plasma Mobile anonymous 10 6,424 03-02-2023, 07:25 PM
  gnome-mobile dev Uturn 1 1,408 02-22-2023, 03:37 AM
Last Post: acrux
  Manjaro plasma-mobile Beta 13 Uturn 13 6,546 01-25-2023, 04:15 PM
  Manjaro Plasma busted Chief 2 1,957 11-22-2022, 05:00 PM
Last Post: Chief
  Axolotl signal client package lolgzs 27 23,209 11-02-2022, 04:55 AM
Last Post: shulamy
  Disabling screen timeout for plasma mobile rp3 7 8,287 09-05-2022, 03:50 PM
Last Post: christev1
  VPN on Plasma Hobgoblin 1 1,545 08-29-2022, 03:14 AM
Last Post: saddamus
  manjaro-pinephone / plasma-mobile-dev: Update broken Uturn 32 33,484 07-28-2022, 12:40 PM
Last Post: johaennessen
