Jami on Pinephone [ IM and VOIP ]
It is a qt6 problem - see this post
(06-08-2022, 11:48 AM)Fish Wrote: You can try the flatpak. I used it for a short time on mobian and it used to work fine.
You mean use flatpak to install the same app that's not working now under this OS? Or using flatpak to install some other SIP/VOIP softphone? If the latter, which one to install? Any recommendations?
I'm sorry for not being more clear. I meant using flatpak to install Jami. I just checked it on mobian and it works quite well.
(06-08-2022, 01:53 PM)Fish Wrote: I'm sorry for not being more clear. I meant using flatpak to install Jami. I just checked it on mobian and it works quite well.
Thanks for clarifying. I tried the flatpak version under Manjaro-ARM (Plasma) and it behaves the same as the non-flatpak one. I get only a splash screen when I try to run the app and it seems afterward at some point to just unceremoniously abort. Guess I'll have to try Mobian or some other OS to get SIP/VOIP functionality out of my PinePhone.
What is the error  if you run jami-qt from the command line?
My error is
jami-qt: symbol lookup error: jami-qt: undefined symbol: _ZN3lrc3api11PluginModel26getPluginPreferencesValuesERK7QString
Out of interest, compare the results of
pacman -Fl qt6-webengine
on your Pinephone and on your x86-64 machine. On teh Arch pinephone and Archlinux x86-64 PC they are hugely different.
PS. if you get an error run
sudo pacman -Fy
to get the pacman file lists
  Fedora + Phosh for PinePhone njha 77 205,813 01-14-2026, 12:22 AM
  Difficulty with openSUSE Tumbleweed Install PinePhone Beta danm1988 0 396 11-17-2025, 07:49 AM
Last Post: danm1988
  Movuan distribution for PinePhone merom 5 5,405 07-27-2025, 05:01 PM
Last Post: merom
  baremetal via Zig on PinePhone - JumpDrive help please WhiteHexagon 1 3,442 07-07-2025, 10:33 AM
Last Post: WhiteHexagon
  Jami on the Pine phone ? bcnaz 8 13,785 06-09-2025, 04:17 PM
Last Post: j_s
  Latest firmware for PinePhone modem! Subsentient 105 211,941 02-02-2025, 08:47 PM
Last Post: bacydentir85
  VoIP with SIP Mangled 9 16,318 01-13-2025, 03:09 AM
Last Post: kathrin
  Slarm64 on PinePhone [Unofficial Slackware ARM - 64 bit] acid andy 40 58,557 12-28-2024, 12:19 AM
  Office applications for the Pinephone Peter Gamma 2 4,685 09-05-2024, 09:22 AM
Last Post: Peter Gamma
  Struggle to install LibreOffice on the PinePhone Peter Gamma 50 65,479 07-26-2024, 10:35 PM
