Is the A64’s true hardware random generator activated in Mobian’s 5.10 kernel build?
The 5.10 kernel release brought support for the Pinephone A64 processor’s true hardware random number generator under the sun8i-ce module. However, even after I load the module I am not getting a working /dev/hwrng.
The patch adding this support to the 5.10 kernel provides a new kernel option that must be activated before building the kernel:
+config CRYPTO_DEV_SUN8I_CE_TRNG
+    bool "Support for Allwinner Crypto Engine TRNG"
+    depends on CRYPTO_DEV_SUN8I_CE
+    select HW_RANDOM
+    help
+      Select this option if you want to provide kernel-side support for
+      the True Random Number Generator found in the Crypto Engine.
Is this option selected in Mobian's kernel build? If not, could I request that it be activated?
You may need to file this on the mobian bug tracker
+    select HW_RANDOM
+    help
No, Mobian stock kernel does not have this set. You can easily find out for yourself:
mobian@pinephone:~$ zgrep SUN8I_CE /proc/config.gz
CONFIG_CRYPTO_DEV_SUN8I_CE=m
CONFIG_CRYPTO_DEV_SUN8I_CE_DEBUG=y
# CONFIG_CRYPTO_DEV_SUN8I_CE_HASH is not set
# CONFIG_CRYPTO_DEV_SUN8I_CE_PRNG is not set
# CONFIG_CRYPTO_DEV_SUN8I_CE_TRNG is not set
Thanks, I have filed a bug on the Mobian tracker. Sorry that I forgot all about /proc/config to see what kernel options had been selected at build time.
  Mobian MMS/SMS text problem bcnaz 16 37,104 06-23-2026, 06:53 AM
Last Post: mehdy
  Mobian image for the PinePhone Korfou 2 1,418 04-27-2026, 09:57 AM
Last Post: Korfou
  reset wifi hardware/driver when it dies through console on pp? tuxcall 5 6,774 03-10-2026, 04:43 PM
Last Post: baptx
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 80 64,346 12-24-2025, 12:11 AM
  cryptocurrency on mobian/pinephone biketool 33 71,170 10-08-2025, 06:21 AM
  XLibre for Mobian Hiraghm 0 3,180 06-29-2025, 12:38 PM
Last Post: Hiraghm
  Axolotl on PinePhone / Mobian arno_nuehm 223 334,049 06-25-2025, 01:19 PM
Last Post: anonymous
  VoIP account on mobian dialer j_s 0 2,875 06-15-2025, 04:19 PM
Last Post: j_s
  Mobian Pinephone Notification LED biketool 2 3,903 06-07-2025, 03:19 PM
  Vivaldi Web browser nearly native for Mobian biketool 3 4,611 05-06-2025, 02:19 AM
