Disassembling PineBook Pro Docking Deck (due to disappeared microSD card)
Question
unfortunately a microSD card "was eaten by" / disappeared inside the "Docking Deck".
This happened because I was careless and on the other hand because the slots and sockets/plugs in the "Docking Deck" housing were not well aligned.
The question now is, how the "Docking Deck" housing can be opened (without damage) to remove the loose, freely moving SD card.
Any advice is welcome, thanks.
Gritibaenz
Big Grin
(01-16-2021, 09:39 AM)gritibaenz Wrote: Hello,
Gritibaenz
Solved. See attachment.
.pdf   opening_PineBookPro_DockingDeck.pdf (Size: 74.05 KB / Downloads: 765)
Seems like it involves some destructive activity?
I've also had the same issue (microSD card disappeared), and I want to thank @gritibaenz for this thread!
I want to add that there is non-destructive way to open the case, just heat the black cover (I've used my wife's hair dryer, no special hot air gun is needed) and pry it after the glue melts:
Then the housing can be opened.
It was a little bit weird that the two screws are different sizes, but anyway. Everything works after the reassembly.
Exact same oopsie.  But the larger issue is how to bend stuff so that it lines up properly?  I was too afraid to just start prying.
  HDMI or VGA From Pinebook Pro via Pinebook Pro Docking Deck? segaloco 5 7,245 01-02-2026, 04:26 AM
Last Post: stu73
  pinebook pro dixplays vertical stripes WEF 2 3,194 03-23-2025, 03:31 PM
Last Post: WEF
  best way to get a stuck sd card out? elix 3 2,801 03-14-2025, 02:43 AM
  Yet another new Pinebook keyboard problem MikoBob 3 3,752 09-11-2024, 07:05 AM
Last Post: MikoBob
  Pinebook Pro on Debian 12 Power Issue u974615 1 3,367 03-13-2024, 10:46 AM
Last Post: u974615
  Pinebook Pro Source for Trackpad Flex / Ribbon Cable rankharris 1 3,326 02-17-2024, 07:06 PM
  Pinebook Pro charging issues tomekdev 1 2,893 01-05-2024, 08:40 PM
Last Post: tomekdev
  Replacement battery for PineBook Pro DrYak 3 5,305 11-07-2023, 10:09 AM
Last Post: DrYak
  Pinebook Pro Revised Keyboard Firmware jackhumbert 73 201,881 09-13-2023, 03:43 AM
Last Post: k3dAR
  PineBook Pro dead ottahe 9 12,807 01-18-2023, 07:41 PM
Last Post: ottahe
