Pinephone mainboard v1.2 documentation update?
Hi!
This thread may go out to the pine64 crew...
Maybe it would be possible to get an update on the mainboard placement documents.
PinePhone mainboard bottom placement v1.1 20191031.pdf
PinePhone mainboard top placement v1.1 20191031.pdf
There's still v1.1 available in the wiki, but it would be nice to get these documents referenced to the v1.2 boards.
Another thing to mention is, that it would be really nice to know about the exact position of the testpoints.
This might be helpful for debugging and low-level programming... or weird addons.
So far i made a list with the schematics as a reference.
v1.2 mainboard bottom:
in the middle nearby the mpu (U1, upper left):
T500 -> CPUS-UTX  (AR100 UART TX, disabled in crust, used as WL-PMU-EN)
T501 -> CPUS-URX  (AR100 UART RX, disabled in crust, used as WL-WAKE-AP)
T502 -> HDMI-CEC
T503 -> FEL  (pull low to enter FEL mode, USB-Boot)
next to ANX7688 (U1304):
T1300 -> ANX_CSDA
T1302 -> ANX_CSDL
T1502 -> GPIO0 (ANX7688
v1.2 mainboard top:
beneath J1101:
T1100 -> CTP-RST
T1101 -> CTP-INT
T1102 -> TWI0-SDA
T1103 -> TWI0-SCK
T1104 -> GPIO0-LDO (VCC-3V)
above J1200:
T1202 -> POWKEY
T1203 -> VOL-
T1204 -> VOL+
next to J1300:
T1 -> USB0-DP
T2 -> USB0-DM
T3 -> DCIN
T4 -> VBAT
in the middle nearby the modem (U1500):
T1503 -> HTXCN
T1504 -> HTXCP
T1505 -> HTX0N
T1506 -> HTX0P
T1600 -> 4K7_PD
T1601 -> USB_BOOT
The group of the HDMI signal pairs are just a guess, as we don't know the position yet.
The only reference i found in the wiki were the USB_BOOT (Modem) pins...
The craziest thing ever would be, if the board-files (e.g. gerber-data) could be shared...
Best regards,
scholbert
(01-05-2021, 07:49 AM)scholbert Wrote: This thread may go out to the pine64 crew...
(01-05-2021, 07:49 AM)scholbert Wrote: There's still v1.1 available in the wiki, but it would be nice to get these documents referenced to the v1.2 boards.
+1, please :-)
Over here, we determined the pinout of the pogo pins to be
PIN6 PIN2 PIN4
PIN1 PIN5 PIN3
Especially because these pins aren't numbered "in order" in the layout, it would have saved some work if we just had a placement document with labeled testpoints to start with.
So I would add these to the list:
T900 -> USB-5V
T901 -> PL12-POGO-INT33
T902 -> DCIN
T903 -> PE14-TWI2-SCK33
T904 -> GND
T905 -> PE15-TWI2-SDA33
  Pinephone - broken power button rorus 14 22,277 05-17-2026, 03:52 PM
Last Post: EuvzO8
  Pinephone + Keyboard for sale, little use ruemoo 15 10,168 03-05-2026, 10:14 AM
Last Post: diazman39
Video Questions about filming video with the Pinephone MirceaKitsune 11 18,807 02-10-2026, 07:46 AM
Last Post: georgegohl888
  PinePhone 16 GB – Free to a Good Home Anna 2 1,129 01-20-2026, 01:43 PM
Last Post: Anna
Bug PinePhone modem keeps "disappearing" Kevin Kofler 17 18,436 12-12-2025, 03:27 AM
Sad PinePhone USB-C port and audio jack failure Kevin Kofler 5 7,308 12-11-2025, 08:57 AM
Last Post: jakfish
  Recycling pinephone as home server mdk 6 2,302 12-01-2025, 02:57 AM
Last Post: mdk
  PinePhone, PinePhone Pro, Keyboard/Accessories for sale brb78 5 1,719 11-30-2025, 05:45 AM
  Modem Issues with the Pinephone Temmie19 5 5,164 07-02-2025, 12:50 PM
Question Third-party cheap touchscreen/LCD for the Pinephone - lost knowledge? mikeb 2 3,641 06-21-2025, 05:19 PM
Last Post: mikeb
