Pinecil Broken?
Hello, juste received my pencil (and 2 other for family and friends) yesterday.
Mine worked on a laptop power supply (19V) no problem.
I try it on a usb power bank didn't know if qc3 or something else hit + button.
It seems to heat then a messsage that says low voltage or something, I removed the usb cable.
And back to 19V, nothing on screen. After didassembly I check 3v3, it was 0.7V and it draw 80ma when on 19V.
5v is 4.2v like in the schematics, so I desolder the 3v3 voltage regulator and it draw 2ma.
check continuity betwen 3v3 and gnd and got 5ohms not good, I replace the voltage regulator by a generic LD1117 3.3v.
here the grotesque picture.
[Image: 1S2-MfsJ1bWqdHaFkLEPkdNFBLiM7zQc5?e=down...5jusharing]
And its back to life sort of, it draw 200ma when idle the other are around 10ma. and the U1 chip FUSB302MPX is extremely hot.
the 3.3V is at 3V and it show 21 V instead of 19 it look "normal" considering the voltage divider.
my next step is to desolder the U1 and check for continuity between 3v3 and gnd but it have to wait until I can get to an air desolder station.
I will tell you that you should'nt try to make it work on 5V, I did it itentionaly but it can happen accidentaly.
I think as it know the voltage some sort of software protection could be implemented to avoid this.
Or I get a bad one, you tell me.
Thanks for reading.
The other 2 are working good.
Pinecil Broken? - by skaaq - 12-29-2020, 01:11 PM
RE: Pinecil Broken? - by VaZso - 12-29-2020, 03:53 PM
RE: Pinecil Broken? - by skaaq - 12-31-2020, 03:34 AM
RE: Pinecil Broken? - by VaZso - 01-02-2021, 04:43 AM
RE: Pinecil Broken? - by skaaq - 01-25-2021, 11:28 AM
  Question about firmware updates on Pinecil V2 helengrace 1 464 10-16-2025, 10:41 PM
  incorporate a multimeter into the Pinecil kellanphil 2 2,200 08-13-2025, 01:14 AM
Last Post: lalisa12
Lightbulb Pinecil -> Pinegun? Avamander 21 33,968 01-21-2025, 01:09 PM
  Will the Pinecil work for repairing iPods, in particular the 30pin port connector? drewdavis 0 1,117 08-27-2024, 08:01 PM
Last Post: drewdavis
Question How many SPI ports/buses are broken out/available on SOQUARTZ? gogerriko 5 5,218 04-05-2023, 10:34 AM
Last Post: gogerriko
Exclamation What is this - Pinecil V3? andrea6 2 14,782 12-19-2022, 08:11 PM
  on pinepower, pinecil stopped working.. sanderboer 1 2,692 09-23-2022, 03:47 AM
  Just got my Pinecil donwynne 1 2,851 04-22-2022, 07:01 AM
Last Post: bbeeast
  Broken forum? arno_nuehm 16 16,082 03-12-2022, 03:00 AM
Last Post: arno_nuehm
  Pine64 Zoho support site broken anomaly 2 4,922 02-08-2021, 09:03 PM
Last Post: anomaly
