I used to be a tinkerer of my Android phones for long time and being an arm device I thought this would be similar. In Android I used an app called Tasker and would create a task with shell commands to change my gov and clock speeds, I guess this would be like cron jobs or similar for the Linux community out there. When I search how to do this in Manjaro, a lot of other forums suggest to use the Manjaro Setting Manager. Though there isn't a kernel setting within this manager which makes me think it's handled differently on a non arm Manjaro dist. I tried searching the pine forums but with no success. How does one change the voltage and clock speeds of the cpus in Manjaro arm for our pb pros?
Changing cpu speed can be achieved via modifying file /sys/devices/system/cpu/cpufreq/policy0/scaling_max_freq and /sys/devices/system/cpu/cpufreq/policy0/scaling_max_freq, assuming you are using schedutil scheduler. This process is the same regardless of which distribution you use or which arm device you use. As long as you're running linux, cpu speed can be altered this way. By the way, you should only use schedutil because this is a cpu with a mixture of big and little cores. Other cpu scheduler are not optimized to handle this big.little architecture the way schedutil does.
As for the cpu voltage, it cannot be changed during runtime. It can be changed via editing device tree but a reboot is needed for it to take effect. You will need to decompile /boot/dtbs/rockchip/rk3399-pinebook-pro.dtb, edit it, recompile it, and replace the original file.
i just change the governor via
"echo powersave |sudo tee /sys/devices/system/cpu/cpu*/cpufreq/scaling_governor"
be it conservative ondemand userspace powersave performance schedutil
