Troubleshooting RockPro64 + Roshambo case SSD problems
I recently purchased a RockPro64 & Roshambo case, and I installed Batocera Linux on it and enabled the case, everything seems to work but the RoshamboPro kit seems to have a problem when inserting the SSD on the board.
When I insert the SSD into the board, the unit behaves erratically, some of the behaviors I have witnessed include USB panel in front of the unit stops responding, fan stops, SSD is recognized momentarily, top buttons (Power/Reset) stop working and sometimes the LED 706 inside the unit will blink. After removing the SSD, the system behaves normally.
I have rules out a problem with the SSD (It works fine when connecting to other machine) or with the RockPro64 USB3 (when I connect the SSD directly outside the case, it works), but I don't know if it is a problem with the cable connecting the RockPro64 to the board or the Roshambo board itself.
Anyone has experienced similar issues? Any known workaround?
(11-20-2020, 01:57 PM)necoc.yaotl Wrote: I recently purchased a RockPro64 & Roshambo case, and I installed Batocera Linux on it and enabled the case, everything seems to work but the RoshamboPro kit seems to have a problem when inserting the SSD on the board.
Update.
I got a separate RoshamboPro case, and everything looks normal on this one, so I have to assume a faulty board or/and cable.
  where to get debian 12 image for rockpro64? heocb 1 3,335 05-18-2025, 02:30 PM
Last Post: Dendrocalamus64
  Use android on RockPro64 without a LCD screen ? john_nash 0 2,888 03-28-2025, 11:15 PM
Last Post: john_nash
  How to use ROCKPro64 PCI-e X4 to M.2/NGFF NVMe SSD Interface Card jykeith123 1 4,271 11-26-2024, 11:08 AM
  Installing Wifi drive for the RockPro64 John45595 0 3,795 02-10-2024, 11:32 PM
Last Post: John45595
  Roshambo 2023 angeloweb 2 4,833 12-19-2023, 03:07 AM
Last Post: Maxpako
Wink You don't sell case and fan for "ROCKPro64 4GB Single Board Computer"? Clea 1 4,963 09-17-2023, 12:00 AM
  Want to check maximum toggle speed in Rockpro64 board. kundanjha 0 4,000 08-14-2023, 07:55 AM
Last Post: kundanjha
  Unable to boot Armbian on new RockPro64 mooseball 5 11,632 07-14-2023, 08:59 AM
Last Post: rockjonn
  Hardware fix for software sound problem on Rockpro64 Ricks Rockpro 0 4,328 04-06-2023, 03:59 PM
Last Post: Ricks Rockpro
  No sound on Rockpro64 with OpenWrt Patrice 1 5,403 04-06-2023, 02:46 PM
