New OS for RockPro64 is here, TwisterOS Armbian
#91
For anyone on a Mac of Win machine, having trouble with the instruction to edit armbianEnv.txt:
1. Windows and Mac cant out of the box mount the eMMC (and SD I suppose), so you can't edit /boot/armbianEnv.txt
2. If you don't have a linux box at hand, you can use VirtualBox with USB passthrough, following this tutorial:
 https://www.linuxbabe.com/virtualbox/acc...x-guest-os
After configuring the attaching the USB device with your virtual system you will be able to mount the partition and edit the file.
https://github.com/dibrz/ARMBand easily maintain an ARM64 media server
I am having issues using Twister on a Pinebook pro.  This is probably a noob question.  The instructions say after flashing the twister image to edit the /boot/armbianEnv.txt file.  But this file is read only - (I assume because the partition is mounted).  And I haven't been able to figure out a workaround.   Can anyone explain the process of editing this file?
Installing a clean v2.0.3 on rockpro64 works at first.
but after doing apt upgrade and waiting for it to upgrade all the files, it is broken. the display flickers on for a half second. then off for 2 seconds. repeatedly
any idea how to fix this?
the armbianEnv name remains the same. (although I noticed the dtb version updated from v5 to v6 and freescale, amlogic, and allwinner folders were deleted)
changing
fdtfile=rockchip/rk3399-rockpro64.dtb
to
fdtfile=rockchip/rk3399-rockpro64-v2.dtb
makes it stop booting. so it seems to be loading the right dtb file.
  irradium (based on crux linux) RockPro64 riscv64, aarch64 mara 12 19,852 06-27-2026, 04:09 PM
  OpenEuler OS on RockPro64 Yuriy Gavrilov 0 2,759 06-15-2024, 09:38 AM
Last Post: Yuriy Gavrilov
  yocto for RockPro64 Fide 1 4,455 01-16-2024, 10:01 AM
Last Post: Fide
  Installing Ubuntu Server on RockPro64 deutschlmao 2 9,294 10-29-2023, 04:43 PM
Last Post: brotherj4mes
  Vanilla mainline Debian 11 (Bullseye) on the RockPro64 Pete Tandy 22 40,372 08-16-2023, 01:34 AM
Last Post: varac
  slarm64 (unofficial slackware) ROCKPro64 RK3399 (aarch64) mara 54 122,904 08-11-2023, 11:13 AM
  How to enable CoreSight ETM trace on RockPro64 shpark 0 4,155 05-21-2023, 11:34 PM
Last Post: shpark
  Rockpro64 Dead on arrival? quixoticgeek 1 3,718 03-12-2023, 06:55 PM
Last Post: quixoticgeek
  RockPro64 boot questions misterc 3 6,049 01-13-2023, 06:21 PM
Last Post: misterc
  A fix for Bluetooth audio stuttering on the RockPro64 raph 2 4,613 01-03-2023, 06:53 PM
Last Post: raph
