Axolotl on PinePhone / Mobian
(09-27-2021, 01:58 AM)arno_nuehm Wrote: FYI:
Currently, Signal itself is experiencing technical difficulties, but this is not a problem of Axolotl as it seems. So please be patient, if something is not working right. Some UT user cannot send/receive messages, but I cannot confirm these errors on (my) Mobian system.
Have a nice day!
Thank you, @arno_nuehm !
I installed Axolotl on a newly flashed phone (Bookworm with all updates).
I could register it and I could connect it to the desktop application on my laptop.
I have the problem you described above: I cannot send or receive messages. Additionally I cannot add contacts; when I enter the details and press "Add" nothing happens.
However, I can send messages from the desktop app and those messages are the only things that show up in Axolotl: There are no outgoing messages (they just disappear after I type them and press send) there are no incoming messages (they reach the desktop app, but not Axolotl), there only the sent messages from the desktop app.
Have a nice day!
I had exactly this issue too, but it seems to work again, I can't pinpoint the date, but it must be sometime last week. No changes whatsoever (apart from regular apt-get update/upgrade) on my side, so I don't know what happened..
Have a nice day!
Really? That sounds promising! @Anna : Could you re-try your efforts to verify the magic?
(10-21-2021, 01:24 AM)arno_nuehm Wrote: Really? That sounds promising! @Anna : Could you re-try your efforts to verify the magic?
No magic here, I'm afraid.
Unregistered, purged & reinstalled Axolotl and registered it again, but it still does not work.
Strangely, the desktop app on my Laptop still works without relinking it.  If I remember it correctly,  I used to have to link the desktop app to Axolotl again every time I had registered anew. (But I might be wrong about that.) Edit: I could still send messages from the desktop app for a few minutes, but once a message was sent to me, I did not receive it and the setup broke. So I had to relink the desktop app to Axolotl. Axolotl now again shows the messages I send from the desktop app but not the ones I receive. So back to square 1.
(10-20-2021, 07:13 AM)battlegarden Wrote: I had exactly this issue too, but it seems to work again, I can't pinpoint the date, but it must be sometime last week. No changes whatsoever (apart from regular apt-get update/upgrade) on my side, so I don't know what happened..
Perhaps I should clarify: I have never reinstalled/purged/etc. I have axolotl installed since the first debian package and updated with the subsequently released debian packages when they came out. It stopped working after the 1.05 release but I could still receive messages on axolotl and send/receive from the linux desktop app. Then sometime last week axolotl started working again.
The arm64 deb package for Axolotl v1.0.7 is successfully built with a lot of fixes and improvements (v1.0.6 needed some hotfixes).
https://github.com/nuehm-arno/axolotl-mobian-package
These are the main fixes and improvements:
* Fix signal desktop linking by change signal desktop link url
* Fix ineffectual (unused before reassign) assignment of recipient
* Fix add contacts (partially)
* Update electron version
* Fix deleting chats
* Explicitly set ozone platform to Wayland for electron when needed (--> no blurry look and no laggy scrolling!)
Sadly, receiving messages for user with new registrations is still broken, but will be fixed with the next version.
Cheers!
(10-28-2021, 09:44 AM)arno_nuehm Wrote: The arm64 deb package for Axolotl v1.0.7 is successfully built with a lot of fixes and improvements (v1.0.6 needed some hotfixes).
Excellent, thank you! It looks much nicer and the device linking works nicely again.
Many thanks, just managed to upgrade and all went well Wink
I am on Axolotl 1.0.7 and I am unable to receive messages but I seem to be able to send them just fine, started about a week ago. Anyone else having this issue?
(11-17-2021, 10:02 AM)ragreenburg Wrote: I am on Axolotl 1.0.7 and I am unable to receive messages but I seem to be able to send them just fine, started about a week ago. Anyone else having this issue?
Working OK for me: not using daily but could just receive fine
  Mobian repository status henrythemouse 16 8,744 04-10-2024, 10:02 AM
Last Post: diederik
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 15 2,002 03-25-2024, 09:07 AM
Last Post: anonymous
  cant verify mobian image at website gnugpg penguins_rule 0 131 03-18-2024, 08:54 PM
Last Post: penguins_rule
  unofficial kali linux for pinephone help needed pinesmell 5 3,630 01-08-2024, 02:50 PM
Last Post: ERPlegend
  mobian installed to eMMC - how to install tow-boot grump_fiddle_reinstall 6 1,994 11-22-2023, 11:46 AM
Last Post: aLoop100o
  What actions needed to keep on mobian testing user641 3 1,819 09-05-2023, 06:44 AM
  Mobian boot failed with zstd message after upgrade. Mahgue 0 633 09-01-2023, 11:29 AM
Last Post: Mahgue
  how to update mobian over tor vusra 13 6,893 07-09-2023, 08:57 PM
Last Post: vusra
  opensnitch outbound firewall now works on mobian vusra 2 1,898 07-09-2023, 01:37 AM
Last Post: vusra
  Using Nativefier on PP64 with Mobian paulcarton 0 630 07-05-2023, 03:57 AM
Last Post: paulcarton
Users browsing this thread: 7 Guest(s)
