Need help with extra info to resize partition in EMMC
I am new here (and gald to be here). I have the postmarketOS edition, and I would like to flash the EMMC with the last Arch image.
I have the Jump Drive on a SD card and I can boot from it. Also no problem to expose the EMMC drive in my Linux laptop.
Until there all good, but then I become confuse and wnat to be sure I won't make an error :
The wiki instructions says to run cfdisk to resize the partition., this is OK. But I am not sure WHICH partition to resize ?
I can see 2 partitions, the small boot one and a other bigger (Lucks encrypted)
[Moderator edit: Removed image that did not display properly]
Sorry if the question was already answered (could not find it) and sorry for what may be a noob question.....
Do I need to resize (from the image above) sdg1 or sdg2 ? And to be 100% sure.... Must it be ext2 ? Can it be ext 4 ?
Thanks in advance for any help !
Just flash to EMMC using dd or Etcher or whatever. No need to resize. Arch does that. You'll lose the encryption though.
(10-26-2020, 06:44 AM)Veraendert Wrote: Just flash to EMMC using dd or Etcher or whatever. No need to resize. Arch does that. You'll lose the encryption though.
Thanks, I'll do this . (And sorry for the big jibbrish text in the OP, seems I didn't past the image the right way)
Pas de problème
  This is how you flash to eMMC easily Luke 25 36,702 07-08-2021, 06:32 PM
Last Post: Old_Mil
  After flashing UT on eMMC Convergence package not working anymore dfjdw8 0 221 06-11-2021, 12:28 AM
Last Post: dfjdw8
  Can't boot from eMMC or SD card... Nibel 1 336 06-03-2021, 08:41 PM
Last Post: ppafin
  Selling Pinephone 2Gb RAM/ 16GB eMMC Merk 0 451 05-23-2021, 10:12 AM
Last Post: Merk
  Can't start Manjaro from eMMC Gon 2 413 05-22-2021, 09:10 AM
Last Post: kqlnut
  Newbie - Arch Linux - Carrier Info - Thoughts mikehenson 2 455 04-27-2021, 04:39 AM
Last Post: Danct12
  Info about getting a stable experience antoyo 0 385 01-31-2021, 11:19 AM
Last Post: antoyo
  Way to Copy / Clone eMMC for Another Phone Codenul 6 1,101 01-30-2021, 10:56 AM
Last Post: C0ffeeFreak
  Mobian on SD Card or Flashed To eMMC For Better Functionality . . . NobodyNew1 3 1,681 09-17-2020, 11:40 AM
Last Post: LinAdmin2
  Pinephone not booting various OSes (eMMC and SD card) lapinus 3 2,451 07-23-2020, 12:59 AM
Last Post: lapinus
