Fresh image, SIM card working
#21
Are you building the image yourself? Or can it be flashed using the script?
allright looks like
zypper refresh && zypper update
does the trick
#22
I 've been testing the SFOS for about a week now. My findings:
- Camera doesn't work (not a big issue for me)
- Battery is showing the wrong status (sticks at a certain level)
- Modem seems to crash from time to time (BH editon - I am wondering if the modem is scr***d)
- Incomming calls work , outcomming calls work from time to time - I can't hear any modem noises when it doesn't work - so this may refer to the point before this one
- SMS seems to work only when outgoing calls works...
Still the best and most fluid OS for me.
Since I am very happy with SFOS :
If I bought a Xperia and installed SFOS on it - is that still android based or pure linux ?
Look forward to having it as a DD Big Grin
#23
(09-23-2020, 07:51 AM)Helium75 Wrote: I 've been testing the SFOS for about a week now. My findings:
sfos is based on android
> Typically the hardware vendor provides an Android™ Board Support Package (BSP) which allows the Android™ operating system to drive the hardware. Sailfish OS then uses the libhybris layer to connect the linux system into the vendor's BSP.
I'm using it as a dd on an xperia but I'm in the process of replacing mobian on the pp with sfos right now.
  Script not working Andidoko 4 1,550 04-09-2023, 12:03 PM
Last Post: moodroid
  RAW image output only 32MB and not working Kimberley van Buyten 3 1,924 05-30-2022, 08:00 AM
Last Post: acrux
  flash-it.sh script currently unable to create a SailfishOS image acrux 3 3,553 07-23-2021, 01:06 AM
Last Post: OhneZ
  February image, upgrade to SFOS4 defactofactotum 8 7,742 02-24-2021, 09:45 AM
Last Post: defactofactotum
  January image defactofactotum 8 9,201 01-08-2021, 10:27 PM
Last Post: DrPhibes
  December image defactofactotum 3 5,015 12-16-2020, 05:35 AM
