Only enable modem when needed with kill switches
Interesting.
I also see Quectell LTE Modem on USB Bus 003, device 002: ID 2c7c:0125 on my PinePhone.
Problem is: when modem is hardware killed with physical switch flipped "off" and then back "on" - the modem does not re-appear in lsusb output.
At this point running as root
usb_modeswitch -R -v 2c7c -p 0125
gives
Look for default devices ...
No devices in default mode found. Nothing to do. Bye!
It seems that after being killed with hardware kill-switch host has to reset the bus to enable the re-enumeration of the device (source Replicant devs: https://www.mail-archive.com/replicant@o...00700.html)
Is there way to reset USB Bus 003 to force enumeration of attached USB devices?
RE: Only enable modem when needed with kill switches - by sokolgeo - 09-20-2020, 04:40 AM
Bug PinePhone modem keeps "disappearing" Kevin Kofler 17 20,728 12-12-2025, 03:27 AM
  Modem Issues with the Pinephone Temmie19 5 6,182 07-02-2025, 12:50 PM
  FOSS fw problem - PinePhonePro, EG25 modem dukla2000 5 5,940 02-05-2025, 02:30 AM
  Kill switches for Wifi/Bluetooth does not work luxgiammi 0 2,585 10-14-2024, 03:34 PM
Last Post: luxgiammi
  Supported Carrier and Modem Bands NachoMomma 4 8,515 03-23-2024, 02:00 PM
  power circuit can't charge battery and can't supply enough power for modem or wifi vortex 2 5,028 02-17-2024, 04:15 PM
Last Post: vortex
  modem not working michelinux 0 2,521 02-16-2023, 04:56 AM
Last Post: michelinux
  modem not detected al_x 3 8,812 02-15-2023, 11:17 AM
Last Post: fxc
  firmware udate Quectel EG25-G modem alwi 7 14,916 07-06-2022, 01:43 PM
Last Post: user641
  Need command to tell what modem firmware I am on. purpletiger 4 7,945 07-06-2022, 12:35 PM
