Fading screen from 2020 9 8 nightly image
After a week of absence i came back and flashef the 9 8 image onto my pinephone ubport CE. At night all seemed fine. The mobile network still drops out and need a.reboot to wakeup . Being out in broad daylight though i was having problem (i enabled auto screen adjustment) i was having the screen gradually fade on me even when i was typing or trying to navigate the screen. It was a.bit comical as i could never select fast enough to get to the Settings to disable the auto function.
(09-09-2020, 10:45 AM)HLing Wrote: After a week of absence i came back and flashef the 9 8 image onto my pinephone ubport CE. At night all seemed fine. The mobile network still drops out and need a.reboot to wakeup . Being out in broad daylight though  i was having problem (i enabled auto screen adjustment)  i was having the screen gradually  fade on me even when i was typing or trying to navigate the screen. It was a.bit comical as i could never select fast enough to get to the Settings to disable the auto function.
I’m not sure if this is related to your problem, but my Pinephone (with pmOS) also suffers from a similar problem.  The screen dims whenever you accidentally cover the proximity sensor, even when you’re not in a call.  Can you turn covering up your proximity sensor with a finger or something?  It’s located at the left of the speaker grills and camera.
(I put away the phone for the day.  At night, I turn it on again. All was fine. I still made sure to undo the auto brightness just in case. )  I'm not sure I understand where the proximity sensor is? And do you mean that it will dim for when you put it to the ear to talk on the phone?
  Mobian image for the PinePhone Korfou 2 740 04-27-2026, 09:57 AM
Last Post: Korfou
  Trixie - bring up the On Screen Keyboard manually. grump_fiddle_reinstall 0 629 12-23-2025, 04:34 AM
  On-Screen Keyboard Arrow Keys biketool 11 8,815 12-23-2025, 04:25 AM
  How to add an homemade app to the main screen? JChdeL 3 1,379 11-04-2025, 04:13 AM
Last Post: JChdeL
  New Install, apps start but don't show up on screen?! RT3 2 2,681 07-18-2025, 07:56 PM
  mobian phosh on screen keyboard not popping up for Chromium/Electron apps grump_fiddle_reinstall 1 3,794 01-15-2025, 08:08 PM
  Proximity sensor is oversensitive (was "Screen blanks when making call") treebeard 6 9,388 08-05-2024, 06:12 AM
Last Post: baptx
  cant verify mobian image at website gnugpg penguins_rule 0 1,935 03-18-2024, 08:54 PM
Last Post: penguins_rule
  Screen auto-rotation sensitivity mdk 0 2,140 12-26-2023, 06:08 AM
Last Post: mdk
  Screen stay black unless power key pressed short freelectro 0 2,287 06-24-2023, 01:55 PM
Last Post: freelectro
