UPDATED (June 2021): 17-distro multi-boot image for Pinephone (incl. 3GiB variant)
I've prepared a multi-boot image for people who want to easily try as many distributions as possible. Official website is now here: https://xnux.eu/p-boot-demo/
Video: https://www.youtube.com/watch?v=kyvFNGUxtIY
https://megous.com/dl/tmp/multi2.mp4
Or: https://www.youtube.com/watch?v=NqyuKysK6ag
https://megous.com/dl/tmp/multi4.mp4 or https://megous.com/dl/tmp/multi5.mp4
Some history/details are on my blog: https://xnux.eu/log/
You can reach me at p-boot@xnux.eu
Question: which of these distros do you like best?
I haven't had time to play with either of them much. A bunch of them look quite polished already at first look, though.
(09-08-2020, 06:01 PM)megous Wrote: I've prepared a multi-boot image for people who want to easily try as many disitrbutions as possible.
You're amazing. Thank you! I'm looking forward to trying this out.
I imagine for updated versions of the operating systems, there is no easy way to update individual distros?
It's big so it's distributed as torrent only: https://megous.com/dl/tmp/0b32272c297f80...40.torrent (seed if you can)
Many thanks for that brilliant work.
I fully understand that you do not want to have the full downloading traffic on your website. However I never used torrents and was not able to get my installation working.
Therefore my suggestion that you put that image on some common storage server like pastebin and publish that URL heere.
@megous is there a script to setup p-boot or does it have to be setup manually? I gave it a go but the red/green led flashes probably mean mistakes in my boot.conf file. Also, is there any support for glodroid (aosp)?
(09-09-2020, 02:01 AM)nas Wrote: @megous is there a script to setup p-boot or does it have to be setup manually? I gave it a go but the red/green led flashes probably mean mistakes in my boot.conf file. Also, is there any support for glodroid (aosp)?
It's not a Braveheart induced issue, is it?
You're giving too little detail. This is just an image that's meant to be flashed to SD card and has everything setup already. No need to run p-boot-conf.
If you enlarge the partition/filesystem, you can update them the regular way.
At least pureos update worked out fine for me.
I made some files that need to stay the same immutable, so as long as update will not try to overwrite the bootloader, updates should not break my changes to the modem scripts.
To me it looks like an unrelated question (to this image) about p-boot in general.
I'll try to upload beta version somewhere, when it will be available.
(09-09-2020, 03:24 AM)megous Wrote: You're giving too little detail. This is just an image that's meant to be flashed to SD card and has everything setup already. No need to run p-boot-conf.
Yes, I should have been more clear: I was following the p-boot install instructions on the website before you posted this ready-made image. Nevermind, it's a bit off-topic for this thread and probably beyond my skill level.
Thank you, very much for this. I'll try it as soon as i get my pinephone.
One question, could glodroid work with p-boot?
Apparently it is in a very rough state right now but it would like to try it out once it gets more polished.
  pinephone virtual keyboard aular 4 304 04-10-2024, 03:45 PM
Last Post: aular
  PinePhone Doesn't Boot LED Doesn't Show Any Signs When Charging dorkydev 1 201 04-02-2024, 11:50 AM
  PinePhone - boot from microSD laserpyramid 5 475 03-06-2024, 06:37 PM
Last Post: aular
  Are you using the Pinephone as your daily driver? jro 157 108,212 02-18-2024, 11:33 PM
Last Post: aular
  2020 PinePhone Manjaro CE EU for sale, name your price astrojuanlu 7 1,723 02-14-2024, 04:51 PM
Last Post: astrojuanlu
  pinephone is not bootble for the box. ijij 1 578 01-19-2024, 01:29 PM
Last Post: fxc
  Multiple issues with the Pinephone MTXP 12 2,266 12-28-2023, 07:55 AM
Last Post: MTXP
  pinephone repair shop shengchieh 0 477 12-26-2023, 02:42 PM
Last Post: shengchieh
  sudo nano file saving pinephone beta edition CharlesGnarley 4 1,639 12-22-2023, 03:44 PM
  Can't get Mobian on PinePhone to recognise USB-C docking bar duncan_bayne 9 6,863 12-04-2023, 02:14 AM
Last Post: Peter Gamma
