VPN
I went ahead and made a walk through of how I use Express VPN on the PBP. Couldn't post the images here so I used imgur. Here is the link : https://imgur.com/gallery/8RprIyS Hope this helps. If any amendments need to be added let me know. Thanks. Still looking for how to make the VPN connection automatic if anyone knows.
(09-07-2020, 11:55 AM)bastafari Wrote:
(09-07-2020, 09:18 AM)tkudog Wrote:
(09-06-2020, 07:20 PM)bastafari Wrote: All I did personally was download the oven file, pasted the username and password and skipped the ipv4 and advanced tab stuff. Works fine. I wish I could get it to automatically connect instead of having to manually click it from wifi connections.
Yeah, not working for me.  I try 2 different locations and both say attempt times out.
It didn't work for me at first. But after I rebooted and took the same steps for some reason it worked. I'll see if I can take screen shots later.
 It's helpful for me if you can do it.
