Cannot get any Manjaro 20.04 images to boot
I managed to get the Archlinux image to boot both from the USB and microSD but no dice with any of the Manjaro images I tried so far.
I tried with an older 32GB microSD and a very recently purchased 64GB microSD (the same one that works with the Archlinux image) still nothing.
My goal is to do a fresh install (preferably the XFCE variant of Manjaro) on an NVMe SSD, I recently installed the NVMe adapter and an NVMe SSD, once booted in Archlinux I can see the nvme0n1 device.
I updated the SPI flash with the latest version provided by pcm720 that changes the boot order and allows to boot directly from an NVMe SSD.
I physically removed the eMMC from PBP as I don't intend to use it (assuming I can actually get it to boot directly from the NVMe SSD).
Is the reason why Manjaro won't boot from MicroSD because I removed the eMMC module?
Thanks.
(07-27-2020, 03:23 PM)VikJES1959 Wrote: I managed to get the Archlinux image to boot both from the USB and microSD but no dice with any of the Manjaro images I tried so far.
Thanks.
The missing eMMC shouldn't be your issue. Are you trying to boot the Live or eMMC Install img?
I'll attempt to find the Live version of Manjaro with XFCE for the PBP. I didn't even know Manjaro (or someone else) made a Live version and I most likely used the eMMC/SD boot version of it. Thanks.
here's the latest live img(s) for XFCE: https://osdn.net/projects/manjaro-arm/st...fce/20.06/
(07-28-2020, 06:40 AM)tophneal Wrote: here's the latest live img(s) for XFCE: https://osdn.net/projects/manjaro-arm/st...fce/20.06/
Yeah... I tried that version 2 days, still won't boot. Thanks anyway for the suggestion.
(07-28-2020, 07:43 AM)VikJES1959 Wrote: Yeah... I tried that version 2 days, still won't boot. Thanks anyway for the suggestion.
I recall a few other having issues with 20.06 imgs, too. Have you already tried the live 20.04 img? Have you tried the emmc installer versions from 20.04? That should boot from the SD and walk you through installing it to your NVMe.
I was able to dd the archlinux image on the NVMe SSD and it actually booted, I can't fathom why I can't do the same with any of the Manjaro images I tried so far.
Just FYI,  when I installed the 20.04 Manjaro image to my NVME ( i do not have an emmc in the pinebook pro and have the EMMC switch off) I used the image that is made for writing to the emmc,  but  let the installer write to the NVME instead. I am using the KDE plasma image.  I know in the past that for the xfce image,  one had to hit escape a few seconds after the system started to boot to get the installation menu.     I just mention that in case you wanted to try it.
(07-29-2020, 01:16 PM)belfastraven Wrote: Just FYI,  when I installed the 20.04 Manjaro image to my NVME ( i do not have an emmc in the pinebook pro and have the EMMC switch off) I used the image that is made for writing to the emmc,  but  let the installer write to the NVME instead. I am using the KDE plasma image.  I know in the past that for the xfce image,  one had to hit escape a few seconds after the system started to boot to get the installation menu.     I just mention that in case you wanted to try it.
Thanks for everyone's help, I finally got it working!
I dd'ed the manjaro installer on a MicroSD, booted from it and installed the Plasma version of Manjaro on the NVMe. It pretty much worked without a itch.
I would've preferred to install the XFCE variant of Manjaro instead but I guess I can just install XFCE and move to it now that I have a working PBP with Plasma.
  PulseAudio dropouts after Manjaro Testing 2025.07.26 update Dendrocalamus64 2 2,306 08-08-2025, 02:39 PM
Last Post: Dendrocalamus64
  Boot Order in Pinebook Pro food 11 10,195 03-28-2025, 10:08 AM
Last Post: DrYak
  pbp with manjaro arm seems to not find any hardware[no wifi, blutooth or battery] frank_philip 4 3,678 03-15-2025, 01:47 AM
Last Post: frank_philip
  new manjaro install: wlan0 stuck in setting network address zkajdan 5 4,124 02-19-2025, 12:49 PM
Last Post: zkajdan
  Pinebook pro won't boot after bootloader installation jwensouls 4 5,458 08-21-2024, 04:17 AM
  Manjaro Sway Theme Broken Eighty8 1 2,903 03-08-2024, 08:41 AM
Question Manjaro with Full Disk Encryption and GRUB dumetrulo 1 4,575 02-02-2024, 02:45 AM
Last Post: frankkinney
  Manjaro network problem late 2023 acruhl 1 2,555 01-19-2024, 11:32 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 7,087 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 8,136 12-11-2023, 03:47 AM
Last Post: calinb
