Pinebook Pro sometimes Does not boot up correctly
I recently installed Arch Linux on my Pinebook Pro. /dev/mmcblk2p1 is my boot partition and p2 is my root partition. The problem is that sometimes Linux cannot detect /dev/mmcblk2p2. Sometimes, it works fine. Here is the output:
Quote::: running early hook [udev]
Starting version 245.6-8-arch
:: running hook [udev]
:: Triggering uevents...
Waiting 10 seconds for device /dev/mmcblk2p2 ...
ERROR: device '/dev/mmcblk2p2' not found. Skipping fsck.
:: mounting '/dev/mmcblk2p2' on real root
mount: /new_root: special device /dev/mmcblk2p2 does not exist.
You are now being dropped into an emergency shell.
sh: can't access tty; job control turned off
[rootfs ]#
It was working fine a while ago, it only happens sometimes. Using UUID on the extlinux config also results in the same.
I had recently soft bricked my PBP and had to switch off the emmc but it is fixed now, if that is relevant.
Apparently running:
Quote:echo fe330000.sdhci >/sys/bus/platform/drivers/sdhci-arasan/unbind
As suggested by randomuser987987 in the thread Pinebook Pro dead after updating u-boot works in getting the partition to show in /dev. The question is will the changes persist forever?
(07-15-2020, 08:50 PM)decisivedove Wrote: Hi,
[rootfs ]#
Apparently running:
It turns out that the changes do not persist. It only works when it wants to. Is there any way to make these changes persist permanently?
I run arch as you, wich version of upower are you using ?
I ran the one packaged on https://nhp.sh/pinebookpro/ , but if it comes with some benefits (swithing led colors for each boot process, really fast, nearly upstream), it has some high percentage of failure mounting emmc partitions.
I now run the one packaged from manjaro for a week, it is much longer to boot, but it has 100% boot success so far.
git clone https://gitlab.manjaro.org/manjaro-arm/p...ookpro-bsp
cd uboot-pinebook-bsp
sudo dd if=idbloader.img of=/dev/mmcblk2 seek=64 conv=notrunc
sudo dd if=uboot.img of=/dev/mmcblk2 seek=16384 conv=notrunc
sudo dd if=trust.img of=/dev/mmcblk2 seek=24576 conv=notrunc
(07-17-2020, 10:57 AM)rimaille Wrote: I run arch as you, wich version of upower are you using ?
i used the one in the Arch Pine 64 repository of the Arch image. The package was uboot-pbp, I believe. I will try the Manjaro package. Thank you!
  Upgrading Armbian from v24.2.1 gnome, breaks pinebook pro Sb2024 1 11,855 08-09-2025, 06:53 AM
Last Post: Sb2024
  Boot Order in Pinebook Pro food 11 10,195 03-28-2025, 10:08 AM
Last Post: DrYak
  Pinebook pro won't boot after bootloader installation jwensouls 4 5,458 08-21-2024, 04:17 AM
  [Pinebook Pro/Mobian/XFCE4] can fix touch or screen in greeter not both SynthGal 0 2,963 05-31-2024, 09:42 AM
Last Post: SynthGal
  Debian on Pinebook Pro u974615 7 8,500 03-31-2024, 10:11 AM
Last Post: u974615
  Pinebook Pro upgrading from the factory image yamsoup 12 11,146 02-22-2024, 04:02 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 7,087 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 8,136 12-11-2023, 03:47 AM
Last Post: calinb
  Gentoo on Pinebook Pro RELEASE jannik2099 54 133,644 12-08-2023, 11:25 PM
  PineBook Pro seems to go to deep sleep, but doesn't wake up pogo 11 12,392 08-31-2023, 04:20 PM
Last Post: TRS-80
