Pinebook Pro sometimes Does not boot up correctly
I recently installed Arch Linux on my Pinebook Pro. /dev/mmcblk2p1 is my boot partition and p2 is my root partition. The problem is that sometimes Linux cannot detect /dev/mmcblk2p2. Sometimes, it works fine. Here is the output:
Quote::: running early hook [udev]
Starting version 245.6-8-arch
:: running hook [udev]
:: Triggering uevents...
Waiting 10 seconds for device /dev/mmcblk2p2 ...
ERROR: device '/dev/mmcblk2p2' not found. Skipping fsck.
:: mounting '/dev/mmcblk2p2' on real root
mount: /new_root: special device /dev/mmcblk2p2 does not exist.
You are now being dropped into an emergency shell.
sh: can't access tty; job control turned off
[rootfs ]#
It was working fine a while ago, it only happens sometimes. Using UUID on the extlinux config also results in the same.
I had recently soft bricked my PBP and had to switch off the emmc but it is fixed now, if that is relevant.
Apparently running:
Quote:echo fe330000.sdhci >/sys/bus/platform/drivers/sdhci-arasan/unbind
As suggested by randomuser987987 in the thread Pinebook Pro dead after updating u-boot works in getting the partition to show in /dev. The question is will the changes persist forever?
(07-15-2020, 08:50 PM)decisivedove Wrote: Hi,
[rootfs ]#
Apparently running:
It turns out that the changes do not persist. It only works when it wants to. Is there any way to make these changes persist permanently?
I run arch as you, wich version of upower are you using ?
I ran the one packaged on https://nhp.sh/pinebookpro/ , but if it comes with some benefits (swithing led colors for each boot process, really fast, nearly upstream), it has some high percentage of failure mounting emmc partitions.
I now run the one packaged from manjaro for a week, it is much longer to boot, but it has 100% boot success so far.
git clone https://gitlab.manjaro.org/manjaro-arm/p...ookpro-bsp
cd uboot-pinebook-bsp
sudo dd if=idbloader.img of=/dev/mmcblk2 seek=64 conv=notrunc
sudo dd if=uboot.img of=/dev/mmcblk2 seek=16384 conv=notrunc
sudo dd if=trust.img of=/dev/mmcblk2 seek=24576 conv=notrunc
(07-17-2020, 10:57 AM)rimaille Wrote: I run arch as you, wich version of upower are you using ?
i used the one in the Arch Pine 64 repository of the Arch image. The package was uboot-pbp, I believe. I will try the Manjaro package. Thank you!
  Debian on Pinebook Pro u974615 8 449 03-22-2024, 03:57 PM
Last Post: u974615
  Pinebook Pro upgrading from the factory image yamsoup 12 1,125 02-22-2024, 04:02 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 1,921 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 1,981 12-11-2023, 03:47 AM
Last Post: calinb
  Gentoo on Pinebook Pro RELEASE jannik2099 54 86,669 12-08-2023, 11:25 PM
  Boot Order in Pinebook Pro food 8 994 11-23-2023, 07:37 AM
  PineBook Pro seems to go to deep sleep, but doesn't wake up pogo 11 4,930 08-31-2023, 04:20 PM
Last Post: TRS-80
  [Manjaro] u-boot won't boot from eMMC with (unbootable) SD card present zackw 1 1,853 08-21-2023, 09:08 PM
Last Post: vanessadonald
  Would a Pinebook Pro be good for a Linux newbie? cassado10 6 1,326 08-08-2023, 04:58 AM
Last Post: moobythegoldensock
  Install deepin OS on pinebook pro wangyukunshan 4 1,426 08-07-2023, 01:12 PM
Last Post: myself600
