LTE adapter via NVMe
Hello, I'm interested whether anyone here managed to successfully connect an LTE adapter to the PBP via NVMe.
If not, is there anything that would prevent it from being possible?
Please note that the NVMe adapter only supports PCIe interface.
Many LTE M.2 devices require extra things, like SIM card slot supplied to them, from the host adapater. Or a USB interface. Or even a different slot configuration. If you do some research, you may be able to find a LTE M.2 device that is PCIe only, with it's own SIM card slot.
There is a possibility that a different M.2 adapter card will be made available. It's exact feature set, and any release date have not been clearly decided. Here is the forum thread discussing it;
https://forum.pine64.org/showthread.php?tid=9727
Arwen Evenstar
Princess of Rivendale
There's no real benefit of trying to put an LTE adapter inside of the Pinebook Pro.
LTE modems (on M.2 cards) almost always just use regular USB, instead of PCIe.
The additional drawbacks are very high power draw from the modem (the voltage regulators on the PBP can't handle that amount of current) and bad antenna characteristics (because of the large amount of metal in the case).
The voltage regulator issue can be solved pretty easily with a little high-power switch-mode regulator, the antenna issue is a bit more tricky.
Additional USB ports are available inside the Pinebook Pro under the shielding, as unused pins on a USB hub IC.
I'd recommend using external USB LTE modems or your phone (in either USB tethering mode, or via WiFi).
The first option will give you some trouble (due to the high power draw) again, though.
  NVMe drives not detected mattpenn 18 16,633 12-24-2024, 08:54 PM
  NVMe reukiodo 0 464 11-18-2024, 09:00 AM
Last Post: reukiodo
  New Working nVME gilwood 1 1,262 11-17-2024, 04:24 AM
Last Post: reukiodo
  NVME problems 2022 / Intel 660p 1TB Starbug 1 2,889 04-04-2023, 12:16 PM
Last Post: globaltree
Thumbs Up NVMe adapter, Great addition dachalife 2 3,085 11-28-2022, 12:56 PM
Last Post: dachalife
  NVme intall usage? tkudog 2 4,168 03-04-2022, 01:29 AM
Last Post: Tazdevl
  Anyone selling a spare NVMe adapter in Europe? tom.tomasz 1 2,732 01-03-2022, 07:57 AM
Last Post: tom.tomasz
  Mini-Howto: ROCK64 USB 3.0 WIFI Adapter (Rabbit-ear) on Manjaro Dendrocalamus64 1 3,392 11-14-2021, 03:41 PM
Last Post: Dendrocalamus64
  NVMe SSD testing methodology halogen 1 3,674 07-22-2021, 05:57 PM
Last Post: calinb
Question Battery stops charging and NVMe and other media disconnect randomly Eey0zu6O 4 7,008 07-09-2021, 08:45 PM
Last Post: moonwalkers
