Arch Linux ARM on PinePhone
#51
(10-15-2020, 02:07 PM)Danct12 Wrote: Arch Linux ARM (20201015):
  • Linux Kernel 5.9.0
  • Use Megi's modem driver for rfkill and stability.
  • GTK3 upgraded to 3.24.23
  • Megapixels upgraded to 0.11.1
  • phoc upgraded to 0.4.3
  • phosh upgraded to 0.4.5
  • HDMI works on PineTab now (not stable yet)
Download: https://github.com/dreemurrs-embedded/Pi...g/20201015
It is recommended to upgrade after flashing this image to fix Bleeding Tooth security vulnerability. This patch was not included as it was discovered after the image were shipped.
I am unable to boot this version. I get a kernel panic during boot.
(10-15-2020, 03:47 PM)june Wrote: I am unable to boot this version. I get a kernel panic during boot.
Try reboot and see if it still happens. And if it still does, you will have to flash alternative U-Boot (u-boot-sunxi-with-spl-pinephone-552.bin).
It can be flashed by insert the SD card to your computer (or plug in the device with Jumpdrive on) and flash the file by running this command:
dd if=u-boot-sunxi-with-spl-pinephone-552.bin of=/dev/sdcard bs=1024 seek=8
Find me in the forest, when I'm at my lowest. I don't really think you should continue..
HOLD YOUR BREATH.
Thank you, 3rd upgrade successful, Bluetooth settings are now kept through reboots!!!! Have not tested much else yet.
I am finding various software hacks required as I move towards a daily driver and usable PC.
I reboot the phone every morning whether it needs it or not. It is quite reliable as a phone for the rest of the day.
Evolution is the easiest way to access CardDAV and CalDAV data, awkward but easy. To get Evolution to size properly run:
scale-to-fit Evolution on
Veraendert eyes must be much better than mine as I cannot use it for daily use, the only thing I can read is Evolution in the titlebar, lol
To size Contacts properly run:
gsettings set org.gnome.desktop.interface scaling-factor 1
I have not found a way to make Calendar usable. The above scale-to-fit and gsettings command do not work. Still searching....
I am also moving towards using it as a PC by following this: https://forum.pine64.org/showthread.php?tid=10469, pages 3-4. A very useful thread for lots of application tweaks. Had an issue with the repository for gdm. Will try again
After that is to install Kalliope: https://kalliope-project.github.io/ to provide voice recognition. I run this software on machines at home and it is moderately Smile impressive.
HTH
LF
(10-22-2020, 10:40 AM)Lousy Fisherman Wrote: And the Calendar dialogs display properly while running under the gnome shell.... Possibly Phosh not picking something up?
HTH
LF
Whow again! This is massive OS for massive linuxphone!  Smile
Latest Upgrade with 5.9.0 kernel brought almost improvement to my PP expierience.
Just wifi takes a bit more time to wake up after deep sleep, than before. Guess that will be as before soon.
Thanks again and please:  come  on !
Heart
I seem to be unable to record anything in gnome-sound-recorder (or any other recording software). When i hit the record button it just sits there and doesn't do anything. Does anybody have the same problem or can anyone point me in the right direction to fix this? Thanks.
Arch Linux ARM (20201024):
  • Upgrade kernel to 5.9.1
  • Upgrade gnome-software to 3.36.1
  • Upgrade squeekboard to 1.10.0
  • Device now vibrates on boot up
  • Unbreak some XWayland applications (such as Chromium)
  • Epiphany is now the default browser
  • Fixed GTK scrolling
  • Fixed https://github.com/dreemurrs-embedded/Pi.../issues/63
Download: https://github.com/dreemurrs-embedded/Pi...g/20201024
HOLD YOUR BREATH.
If someone has the same problem updating like me: You need to add another repo first in /etc/pacman.conf
https://discord.com/channels/37059558709...9401141268
could you add the docking mode button to phosh??
(10-24-2020, 06:24 AM)Danct12 Wrote: Arch Linux ARM (20201024):
Thank you very much for that interesting image!
Here my observations:
  1. When booting I could not feel any vibration.
  2. After Installation of Epiphany it did not show up in the menu. (Edit: Later it suddenly showed up).
  3. Sound is good quality but rather faint. After installation of alsa-tools and setting the volumes to 100% it is ok, but could not find out how to make these settings permanent?
  4. Could not find out how to get the USB-dock working.
  Updating Arch Linux _radv_ 8 560 02-20-2024, 09:35 AM
Last Post: _radv_
  PinePhone AND/OR PinePhone Pro Arch Complete Install and Setup mikehenson 2 2,050 01-14-2024, 08:43 AM
Last Post: shifras
  How to install arch with FDE user641 3 638 01-11-2024, 10:18 PM
  How to find software app, on Arch Phosh? general_lee 5 1,796 10-15-2023, 10:12 PM
  Arch auto mount usb example Lazy_one 2 2,761 10-06-2023, 09:36 AM
Last Post: luppivega
  Arch with FDE user641 1 837 07-29-2023, 08:27 AM
Last Post: alpineduck
  No keyboard on Arch Plasma when entering password on document Chief 0 798 12-03-2022, 08:35 PM
Last Post: Chief
  Curious About Arch Ferriah 2 2,061 11-07-2022, 04:38 PM
Last Post: Ferriah
  Latest version Arch Plasma looks good. Chief 5 2,310 10-23-2022, 01:53 PM
Last Post: Chief
  Evolution no longer runs on Arch Phosh. Chief 2 1,310 10-17-2022, 07:22 AM
Last Post: Chief
