US SIM Cards not working on Pinephone
I turned my Pinephone on today to find that my SIM card wasn't detected, and I found that my Pinephone is not detecting US SIM cards but after putting in a European SIM card I had it detected it just fine. The 2 distros I was running were UBPorts and Mobian, could one of them have updated the modem firmware causing this issue? I had a US SIM card working just fine 3 days ago but I updated both Mobian and UBPorts also 3 days ago and I wasn't paying attention to the SIM card status.
Edit: It actually appears to work in the factory test but wasn't working in UBPorts or Mobian.
I just got my UBPorts community edition today. The sim card wasn't working. I then noticed that an extra sim card laying around was a bit larger. That one worked. Is it possible that you're using the wrong sized sim card?
I'm using a micro SIM which is the correct size. I put the European SIM on top of my US T-Mobile SIM and its the exact same size.
I think this belongs to the PinePhone forum
My cricket sim picked up and worked fine first try (it's one of the mid-sized sims, I used the sim insert that came in the plastic baggy in the box). I was able to make and receive calls and txts and was getting LTE. After messing with hotspot settings my LTE quit working and I haven't been able to get it back yet :\ This is with the UBPorts edition.
  pinephone virtual keyboard aular 4 304 04-10-2024, 03:45 PM
Last Post: aular
  PinePhone Doesn't Boot LED Doesn't Show Any Signs When Charging dorkydev 1 201 04-02-2024, 11:50 AM
  4G VoLTE calls confirmed working with carrier x dcinoz 15 11,698 03-09-2024, 11:38 PM
Last Post: dcinoz
  PinePhone - boot from microSD laserpyramid 5 475 03-06-2024, 06:37 PM
Last Post: aular
  Are you using the Pinephone as your daily driver? jro 157 108,211 02-18-2024, 11:33 PM
Last Post: aular
  2020 PinePhone Manjaro CE EU for sale, name your price astrojuanlu 7 1,723 02-14-2024, 04:51 PM
Last Post: astrojuanlu
  pinephone is not bootble for the box. ijij 1 578 01-19-2024, 01:29 PM
Last Post: fxc
  Multiple issues with the Pinephone MTXP 12 2,266 12-28-2023, 07:55 AM
Last Post: MTXP
  pinephone repair shop shengchieh 0 477 12-26-2023, 02:42 PM
Last Post: shengchieh
  sudo nano file saving pinephone beta edition CharlesGnarley 4 1,639 12-22-2023, 03:44 PM
