2GB Pine 64 only has 1GB
(07-04-2016, 11:40 PM)JaviLM Wrote:
(05-14-2016, 09:21 AM)longsleep Wrote: You installed a Kernel which does not support 2GB - in fact you installed my very first Kernel release from ages ago. Only you can answer the why. See http://forum.pine64.org/showthread.php?tid=293 for Kernel history.
I'm running into the same issue (only 1GB detected in the 2GB model) and I found this thread via Google.
I followed your instructions to install the new kernel, but after upgrading it can still see only 1GB:
javilm@pine64pro:~$ uname -a
Linux pine64pro 3.10.102-0-pine64-longsleep #7 SMP PREEMPT Fri Jun 17 21:30:48 CEST 2016 aarch64 GNU/Linux
javilm@pine64pro:~$ cat /proc/meminfo
MemTotal:        1003836 kB
MemFree:          778320 kB
Buffers:            9492 kB
Cached:           120692 kB
I'm assuming there's something I'm doing wrong or that I missed some step somewhere. Could you let me know what you'd need from me in order to troubleshoot this?
Thanks in advance,
Any luck with this?
I am having the same issue.
Just to make sure, can you try one of the latest images, like https://github.com/ayufan-pine64/linux-b...118.img.xz and report back? If that one also detects only 1GB, I would go with faulty hardware...
Come have a chat in the Pine A64 IRC channel >>
(03-03-2018, 07:35 AM)xalius Wrote: Just to make sure, can you try one of the latest images, like https://github.com/ayufan-pine64/linux-b...118.img.xz and report back? If that one also detects only 1GB, I would go with faulty hardware...
Thanks @xalius, I will give it a try and update once I do.
I am also suspecting hardware issue.
Bug
I tired and same result
p.p1 {margin: 0.0px 0.0px 0.0px 0.0px; font: 10.0px Monaco; color: #34bc26; background-color: #000000; background-color: rgba(0, 0, 0, 0.85)} p.p2 {margin: 0.0px 0.0px 0.0px 0.0px; font: 10.0px Monaco; color: #f4f4f4; background-color: #000000; background-color: rgba(0, 0, 0, 0.85)} span.s1 {font-variant-ligatures: no-common-ligatures} span.s2 {font-variant-ligatures: no-common-ligatures; color: #f4f4f4} span.s3 {font-variant-ligatures: no-common-ligatures; color: #5230e1} span.s4 {font-variant-ligatures: no-common-ligatures; color: #34bc26}
pine64@pine64:~$ uname -a
Linux pine64 3.10.105-bsp-1.2-ayufan-118 #1 SMP PREEMPT Sun Oct 15 21:40:57 UTC 2017 aarch64 aarch64 aarch64 GNU/Linux
pine64@pine64:~$ cat /proc/meminfo
MemTotal:        1004868 kB
MemFree:          717424 kB
Buffers:            5420 kB
Cached:           202780 kB
SwapCached:            0 kB
Active:            52088 kB
Inactive:         165528 kB
Active(anon):       9560 kB
Inactive(anon):    12972 kB
Active(file):      42528 kB
Inactive(file):   152556 kB
Unevictable:           0 kB
Mlocked:               0 kB
SwapTotal:        502416 kB
SwapFree:         502416 kB
Dirty:                12 kB
Writeback:             4 kB
AnonPages:          9420 kB
Mapped:             7544 kB
Shmem:             13108 kB
Slab:              25388 kB
SReclaimable:      10816 kB
SUnreclaim:        14572 kB
KernelStack:        1568 kB
PageTables:          440 kB
NFS_Unstable:          0 kB
Bounce:                0 kB
WritebackTmp:          0 kB
CommitLimit:     1004848 kB
Committed_AS:      64800 kB
VmallocTotal:   251658176 kB
VmallocUsed:       27084 kB
VmallocChunk:   251619208 kB
HugePages_Total:       0
HugePages_Free:        0
HugePages_Rsvd:        0
HugePages_Surp:        0
Hugepagesize:       2048 kB
So for sure that is a hardware issue  right? There is no BIOS update like procedure for the board that I can do as we usually do in PCs?
what about running a memory tester just to see what happens ?
(03-03-2018, 06:59 PM)dkryder Wrote: what about running a memory tester just to see what happens ?
I installed Armbian and this is what I get one login
Welcome to ARMBIAN 5.38 stable Ubuntu 16.04.3 LTS 3.10.107-pine64
System load:   0.24 0.36 0.22  Up time:       12 min Local users:   2
Memory usage:  17 % of 979MB  Swap usage:    42 % of 489Mb  IP:            192.168.10.240
CPU temp:      39°C
Usage of /:    16% of 15G
Then I tried the memtester and get the following result
dooshi@pine64:~$ sudo memtester 2048
[sudo] password for dooshi:
memtester version 4.3.0 (64-bit)
Copyright © 2001-2012 Charles Cazabon.
Licensed under the GNU General Public License version 2 (only).
pagesize is 4096
pagesizemask is 0xfffffffffffff000
want 2048MB (2147483648 bytes)
got  1116MB (1170866176 bytes), trying mlock ...Killed
Pine64_pictures
You can see the picture of the hardware, its a 2GB model but showing 1GB with all the OS i tried.
I have opened a claim to the seller now as a hardware fault.
