Pinebook Pro (i3 WM): Confirm Shutdown on Power Button
I recently purchased the Pine Book Pro, and for the most part, I've really been enjoying it. However, I was wondering if there's a way to customize the behavior when the power button is pressed.
I'm running Manjaro (the i3 WM variant), and when the power button is pressed, it immediately shuts the system down. While this would normally be fine, the power button is unfortunately where the delete key is on my other machines, so I've hit it by mistake more than once.
Is there a way to configure the power button such that, when pressed, there's some confirmation, instead of an immediate power down?
Thank you for any help in this matter.
I'm sorry, but I have to tell you, you are on wrong forum. This is the pinebook (the ancestor of pinebook pro) forum.
Try your question here: https://forum.pine64.org/forumdisplay.php?fid=111
assuming a mod moves this...
disable the power button in systemd, then map the button in your i3 config.
i use wlogout on sway mapped to bindsym + shift + e inetead of the default and my power button does nothing. i keep pushing it by mistake...
This is how I solved this in sway (wayland). I wanted power button to open be/dmenu with common actions (lock, suspend...).
1. Disable power button handling in logind.
/etc/systemd/logind.conf:
HandlePowerKey=ignore
2. Handle power button in sway.
~/.sway/config:
input "gpio-key-power" xkb_model "pc105"
bindsym XF86PowerOff exec seat
3. Add seat script to your path.
seat:
#!/bin/bash
cmd=`echo -e "lock\nlogout\nsuspend\npoweroff" | bemenu -l 10 -p 'seat>'`
case "$cmd" in
    lock)
        loginctl lock-session
    logout)
        loginctl terminate-session $XDG_SESSION_ID
    suspend)
        systemctl suspend
    poweroff)
        systemctl poweroff
esac
5. For loginctl lock-session to work, you also need something like this (mainly the lock part).
~/.sway/config
exec swayidle -w \
          timeout 300 'swaylock -f -c 000000' \
          timeout 600 'swaymsg "output * dpms off"' resume 'swaymsg "output * dpms on"' \
          before-sleep 'swaylock -f -c 000000' \
          lock 'swaylock -f -c 000000'
  Irradium (based on crux linux) Pinebook A64 (aarch64) mara 3 12,362 11-28-2025, 07:38 AM
  DietPi OS for Pinebook MichaIng 3 13,851 03-11-2024, 05:02 PM
Last Post: oxoocoffee
  Slarm64 on Pinebook [Slackware Arm - 64 bit] KRT 46 92,113 09-26-2023, 03:18 PM
  Broke pinebook GUI, what to do, fix or install new? acruhl 2 4,535 07-13-2023, 05:43 PM
Last Post: acruhl
  Orignal PineBook jwp1000 1 3,446 07-10-2023, 07:44 AM
  Pinebook no longer boots rjtanner 12 12,828 04-13-2023, 01:09 PM
  Stock Debian on original Pinebook moonwalkers 1 7,175 01-29-2022, 10:37 PM
Last Post: cel
  Write image to eMMC - Pinebook 11.6" irongarment 4 9,040 01-04-2022, 09:22 PM
Last Post: irongarment
  E: The repository 'http://pinebook.kde.org.uk bionic Release' no longer has a Release pixelpaperyarn 3 9,820 05-07-2021, 10:20 AM
  pinebook.kde.org.uk no longer has release file?? supermassive 1 7,421 01-20-2021, 11:18 AM
