PBP for Krunker.io
I just received my PBP and in the process of giving it a test drive I checked it out on krunler.io
It runs extremely slow and laggy on firefox. Good connection speeds so I ruled that out.
I switched to chromium but got the following message: Failed to Load Make sure you are using the latest version of Chrome or Firefox
I initially downloaded chromium via pamac-manager, when I got the above message I removed it then downloaded chromium via command line but got the same results.
Two different issue I guess.
First shouldn’t PBP be capable of running krunker.io?
Second why would an error say I don’t have the latest version of chromium?
Thanks from a new PBP owner and new linux user.
