How do the kill switches work?
(05-29-2020, 10:12 PM)pfeerick Wrote: My most pressing question is: How can I, a human, determine the current state of any given kill switch?
"you can't", except, by pressing the button to toggle the state, at which point you'll need to do it again. other than, perhaps, in one or two cases, looking at dmesg or poking the right sysfs bits to see if the device is still present or missing.
Which, of course, is not quite the same. (Especially since, for Wifi, you now have to reboot the machine. Or type an arcane sequence in.)
(05-29-2020, 10:12 PM)pfeerick Wrote: How can software running on the main CPU determine the current state of any given kill switch?
Generally, "you can't", although wifi and camera would probably appear and disappear, so there is that possibility. The caveat being the wifi driver doesn't like the device disconnect, so may need some poking to get it to properly reflect the device absence/presence.
Point of clarification:  That only holds for the camera.
The microphone is a simple analog device.  The microphone kill switch turns on/off a circuit that's parallel to the microphone input; there is no device, or absence thereof, to be detected.
Likewise, the Wifi circuitry is not disconnected. The WIFI_CUT trace goes to a pin that (according to the AP6256 datasheet) internally "powers down the internal regulators used by the WLAN section. When this pin is low the WLAN section is in reset." What that means, exactly, is not elaborated upon further.  (more on that below.)
(05-29-2020, 10:12 PM)pfeerick Wrote: Yup, that would be it. . The SH68F83 is a low speed (i.e. USB 1.1) microcontroller, which being used as the interface between the keyboard matrix and the PBP.
I pointed this out because the wiki page says "The keyboard and trackpad both use the USB 2.0 protocol".  I'm betting the trackpad is 1.1 as well.
(05-29-2020, 10:12 PM)pfeerick Wrote: Where's the source code and build instructions for the keyboard firmware?
The source for the keyboard firmware is not available - the manufacturer would not release that, but did give pine64 updated binaries to overcome the initial issues with keyboard responsiveness.
Now that is not an answer I expected, given the nature of everything else in a Pinebook!
(05-29-2020, 10:12 PM)pfeerick Wrote: There have been efforts to reverse engineer it, and one such is this work by Jack Humbert (check out the firmware/src folder). You'll also find that elusive datasheet in the repo. Wink
I'm not even convinced that what's needed counts as "reverse engineering".  We just need to write our own (open) firmware.
Based on the pinout laid out on the schematics, it's probably a basic switch grid design.  (As I said, I've worked on them before, though that one was a numeric keypad, it only had 12 keys.)  The principle is pretty simple:
1. Enable internal pullup on column pins, set to input mode.  They will float high.
2. Write an active 0 to all row pins.
3. Register to be interrupted when any column pins goes to 0
4. When IRQ is signaled, disable interrupt and start timer
5. When timer goes off, put all rows but R0 into high-impedance mode.  Note which columns read 0.  Then repeat this for all other rows.
   Now you know exactly which keys are currently being pressed.
6. As soon as no keys are pressed, disable timer and reenable interrupt
(Depending on MCU limitations, you might have to have the timer on all the time; doing so still works, but consumes more power.)
Anyway, thanks for pointing me to that; I think I'll talk to @jackhumbert about the possibilities here.
(05-29-2020, 10:12 PM)pfeerick Wrote: One thing in particular is that if you turn off the kill switch, wlan0 doesn't disappear; however, if the laptop is powered on with the kill switch already inactive, wlan0 never appears in the first place.  I'd like to better understand why this is.
Probably related the WiFi driver not understanding how to cope with the WiFi module just suddenly dropping in or out of existence, rather than via some software instruction. That's why these commands are needed to kick it back into life if you turn it on (probably just the unbind command would refresh things if you turn it off, meaning you'd then only have to bind it when turning it back on).
$ echo 'fe310000.dwmmc' | sudo tee /sys/bus/platform/drivers/dwmmc_rockchip/unbind
$ echo 'fe310000.dwmmc' | sudo tee /sys/bus/platform/drivers/dwmmc_rockchip/bind
As I pointed out above, I don't think that's exactly what's happening.  This is what I suspect happens: (of course, I could be wrong.  That's why I said I want to better understand this.)
== Process when starting up with kill switch active ==
1. Something causes the kernel driver for the wifi chip to be loaded
2. The driver starts by initializing the wifi circuitry
3. If the kill switch is off, the wifi circuitry does not respond to the driver's commands, and it aborts without creating wlan0
== Process when toggling kill switch while power is on ==
1. Key sequence entered, disabling wifi ("putting into reset")
   This has the effect that the initialization done by the driver at boot time is undone.
2. Key sequence entered, re-enabling wifi ("out of reset")
3. At this point, the wifi chip is now enabled, but no longer initialized.  Because of this, it does not properly respond to commands from the driver.
    (And the driver has no way of knowing this has happened.)
My understanding is that the "unbind/bind" thing has the effect of
1. unbind => tell kernel to have the current driver stop being in charge of that device
2. bind => tell kernel to use the specified driver to be in charge of that device
That has the effect of forcing the driver to be reloaded -- and since the first thing it does is (re)initialize the wifi chip, it works again!
(05-30-2020, 03:21 PM)Arwen Wrote: For the first, I've updated the Wiki to indicate it's stored in the keyboard's flash memory.
Just to be clear: @pfeerick says it's in EEPROM storage, and I suspect he's right.  (The relevant difference is whether or not the kill switches are preserved when the flash memory is rewritten during a firmware update.)
(05-30-2020, 03:21 PM)Arwen Wrote: One note, Jack's keyboard firmware can send a special key sequence on disable and enable of the kill switches. This is to allow future OS level detection of change, like re-enabling WiFi chip. It's still early days, so we will have to see if Jack's firmware becomes the "new" default firmware. Already we have seen a change in the default OS from Debian to Manjaro.
I can't imagine that it wouldn't be; it's keyboard controller firmware.  It either does its job or it doesn't.  The only distinguishing factor here is closed-source vs open-source, and I find it difficult to believe that the kind of people who are interested in Pinebooks wouldn't embrace the latter.
How do the kill switches work? - by Stevie-O - 05-29-2020, 04:28 PM
RE: How do the kill switches work? - by Arwen - 05-29-2020, 04:38 PM
RE: How do the kill switches work? - by Stevie-O - 05-29-2020, 05:43 PM
RE: How do the kill switches work? - by pfeerick - 05-29-2020, 10:12 PM
RE: How do the kill switches work? - by Arwen - 05-30-2020, 03:21 PM
RE: How do the kill switches work? - by Stevie-O - 05-31-2020, 09:02 PM
RE: How do the kill switches work? - by Arwen - 06-01-2020, 09:08 AM
  Does latest Tow-Boot install/work correctly for everyone? tophneal 4 1,833 08-03-2023, 03:30 PM
  eMMC for Odroid C4 work in PBP? dieselnutjob 6 3,384 04-05-2022, 10:10 AM
Last Post: jiyong
  Forgot my Pinebook password. Booting from MIcroSD doesn't work. ksfoodforest 0 1,748 01-30-2021, 11:08 AM
Last Post: ksfoodforest
  Did I kill my PBP's board? overlisted 7 7,437 11-12-2020, 03:28 PM
Last Post: overlisted
  Soft restart doesn't work dgkPBP 9 8,674 09-19-2020, 09:40 AM
  Privacy switches not persistent yawnoc 0 1,721 07-16-2020, 12:01 AM
Last Post: yawnoc
  Does Fastboot Devices tools work on Pinebook Pro? pinejolla 6 7,441 06-16-2020, 03:14 AM
Last Post: FeMike
  pinebook pro overheats and switches off when streaming leonidas 13 14,124 04-20-2020, 09:05 AM
Last Post: bcnaz
  Clarification on Privacy Kill Switches jabo 3 5,434 10-04-2019, 07:27 AM
Last Post: jabo
